[Mod] #Smart #Card #Key (Credit Card style key) for GX460 / FOB Programming
Old 09-27-23 | 05:25 AM
  #241
John00's Avatar
John00
Originally Posted by achillar30
What year is your GX? If your main key FCC ID isn’t the same as mine, I doubt it’s going to work with the same card key I used. You need to find which other models/years use the same regular key as your car and order the card key for one of those models.
why do you doubt it will work because of a different fcc id?
Old 09-27-23 | 10:53 AM
  #242
achillar30's Avatar
achillar30
3rd Gear
The correct card key depends on the FCC ID of the main key. In my post my main key is HYQ14FBF, which is the same as some years of the UX. The card key for those UXs is HYQ14CBM. The car will only recognize a certain compatible frequency for keys, so you can think of them as pairs almost…if your main key has a certain FCC ID, the card key that will work with it has a certain FCC ID.
Old 09-30-23 | 07:44 AM
  #243
John00's Avatar
John00
sort of. the FCC ID is based on HW, MFG, and of course need cert. Multiple cards from different manufacturers with different FCC IDs will work. You do need to match freq. protocol and card/chip are needed to pass the access check.
think about all the different devices we use today. 2.4 wifi with many FCC ID items, 5 also. even bluetooth.
how the car works is that theres a low current circuit waiting for some activation. when received, then the next circuit section activates, received the the card/chip ID, sends through bus to the controller for verification. if verified then a signal goes to another controller to unlock.
for any vehicle the mfg might only use one supplier for the chip, but there are always secondary options already vetted in case the mfg cant get supplied from the same supplier. these will have different FCC ID because they have different HW and certs, but will have the same protocol and freq. so a mfg might only have released one version and we see only one FCC ID, but unless you check the BOMs and then the part drawing and then supply chain records you wont know if theres only one FCC ID released by the mfg. but for sure there are many FCC IDs that will work, including portable access tools used by locksmiths, some shops, and crooks.
achillar30 (09-30-23)
Old 10-05-23 | 05:33 PM
  #244
rwfvohq2's Avatar
rwfvohq2
how to deal with pass-code which is requested by techstream version 17? I bought the new 2023 GX, register a new smart access process ask me input seed number to generate pass-code online with toyota
Old 01-30-24 | 09:53 AM
  #245
JustenCase's Avatar
JustenCase
2nd gear
Originally Posted by rwfvohq2
the FCC ID on my key fob is HYQ14FBZ which is differ from yours. I just ordered 89904-48X70 card key according to your spec above. finger cross and I hope they can pair...
interestingly, newer 2020-2023 card key 89904-48X70 is $50 cheaper than older 8999448142 one
@rwfvohq2 Did the 89904-48X70 card key work for you?
Old 10-20-24 | 06:48 AM
  #246
Kbobur's Avatar
Kbobur
2nd gear
Default 2021 GX 460 programming Successful
2021 GX 460 smart key programming successful. Used 89904-48X71 smart key. Did programming using techstream and a chinese cable from amazon. Cable came with a free techstream software. On the first try 89994-48142 did not work I guess because it workes on a different frequency.
MrBigE (10-22-24)
Old 10-20-24 | 09:45 AM
  #247
Brian06090's Avatar
Brian06090
7th Gear
Default Help
I purchased the same could never get it to load
I even tried using an old laptop with windows 7.
If I can ask, which system did you buy, eBay ? And which version of windows did you use? Was it a problem?
Old 10-20-24 | 01:28 PM
  #248
Kbobur's Avatar
Kbobur
2nd gear
No, I did not face any problem. I used this one from amazon https://a.co/d/68Mjvh3 and an old windows 7 laptop. The cable came with installation software on a DVD Rom disk. Finding disk reader was more difficult than anything else here.
blanks81
GS F (2016-present)
59
09-25-24 01:23 AM
theoryguy3
01-15-14 09:54 PM
Lexy88
ES - 5th Gen (2007-2012)
02-06-12 11:35 PM
