Coolant Flush / Fluids / Questions / Comments
Old 03-31-20, 05:09 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,666 Likes on 2,400 Posts
nuclearn8 (03-31-20)
Old 04-01-20, 08:06 AM
nuclearn8
nuclearn8's Avatar
Originally Posted by Acrad
Are you aware what the FSM states for this procedure? Is techstream used (could the obd2 and app be substituted within the procedure?) ... curious if it's as simple as the OP states to do properly... never done coolant in any vehicle.
Old 04-01-20, 08:37 AM
ChrisOK
ChrisOK's Avatar
Getting ready to change belts and hoses and flush coolant. Thank you guys for the awesome write up!!!
Does anyone know if the LS460 has the same block drain locations? Doing the wife's car as well since we are on full quarantine...
Old 04-01-20, 09:29 AM
Jacket
Jacket's Avatar
I'd be surprised if they were in a different location. I believe the majority of the differences between the LS and GX engines are on the top end. Only one way to truly find out though....
Old 04-01-20, 09:44 AM
ChrisOK
ChrisOK's Avatar
I will let you know tomorrow!!!
Old 04-01-20, 03:32 PM
Acrad
Super Moderator
Acrad's Avatar
I don't see anything about TS or OBD methods. Attached are coolant replacement instructions.
File Type: pdf
The following 5 users liked this post by Acrad:
cancruiser (03-21-24), chrisca70 (10-02-21), dwh13 (04-01-20), LokiGx (11-23-20), nuclearn8 (04-01-20)
Old 04-01-20, 05:34 PM
nuclearn8
nuclearn8's Avatar
That procedure looks easy and no reason cant do it now with confidence. Thank you very much.
Old 04-03-20, 08:56 AM
ChrisOK
ChrisOK's Avatar
So I decided to do the LS460 first. The engine block drain is up and behind the alternator. I managed to get a socket on it put could not turn it, basically impossible to get to the fitting. So I just went with draining as much as I could and changed the hoses and belt. Doing the GX today.
Old 04-11-20, 06:46 PM
nuclearn8
nuclearn8's Avatar
@ChrisOK How'd the GX procedure go? you find both the block drains?
Old 04-13-20, 01:01 PM
ChrisOK
ChrisOK's Avatar
It went well drivers side drain **** is fairly easy to get to, passenger side was difficult. Drained the Driver side first and it was a lot of fluid, passenger side was minimal. I would recommend doing the driver side and if you don't have the ability/patience to get to the passenger side drain you could skip it. It is definitely worth while draining the block.
The following 2 users liked this post by ChrisOK:
Acrad (04-13-20), nuclearn8 (04-13-20)
Old 04-18-20, 11:00 PM
ninja250
ninja250's Avatar
I have drained the radiator and the block from the drivers side, all 2 gallons. Looks like its half of the coolant, i just refilled, as not sure how to drain the rest and did not want tonspend another half day to get 1 more quart from the system. The access of the drains is pretty difficult, but this writeup helped a lot!
The Toyota coolant freezing temperature is -34F, is there any coolant or a concentrate mix that would have a lower freezing point?
Old 04-19-20, 06:45 AM
ChrisOK
ChrisOK's Avatar
-34 F (-37 C) is the lowest temperature freezing point of any anti-freeze/coolant. You would have to use a block heater to overcome anything lower.
My personal option is to never go anywhere the temperature gets that low!!!
The following 3 users liked this post by ChrisOK:
cancruiser (03-21-24), Jamodah (12-30-20), nuclearn8 (04-19-20)
Old 05-22-20, 04:08 PM
Lavrishevo
Lavrishevo's Avatar
Default Testing the coolant PH with a multimeter
This is a good way to check your coolant quality
Acrad (05-22-20)
Old 05-22-20, 04:27 PM
Acrad
Super Moderator
Acrad's Avatar
Interesting... I thought I remember seeing this years ago and never tried it out. I'll have to check mine to see what it is at. My water pump was swapped with several gallons of new coolant about half my current mileage ago.
Old 07-28-20, 11:40 AM
Yurka
Yurka's Avatar
Default Engine coolant on GX
Hey, i got a reminder on my car that its time to replace my engine coolant. I was wondering if i only gotta stay with Toyota Super Long Life Coolant or perhaps i could just go to a local AutoZone instead of a dealer and get equivalent coolant, 50:50 pre-diluted mix instead of driving all the way to the dealer, live quite far from one.
Quick Reply: Coolant Flush / Fluids / Questions / Comments
