Lane change auto flashing mod completed
#76
#77
Can you confirm if the signal trailer hitch is working as well after this mod ?
#79
I am in the middle of the project right now..how did u fit the 8 pin relay into the original relay? I am trying to plug the pin relay but the pins of the female are too small and won't fit this 8 pin relay that I bought from ebay. Any hints on what you did?
#80
The easiest way for me was to tap into the relay wires. I was recommended “posi-taps” by a couple members on here. Much better than the vampire clips, but the posi-taps are a bit difficult to find in store.
#81
EDIT: After looking at original poster pictures more carefully, looks like I am missing one piece (red) that I didn't buy that's where I plug the 8-pin relay to it. Anyone one has link to that red flashing relay?
#82
No that' not my question, I already tapped the wire as the OP did in his post. My question is how do I plug the 8 pin or where do I plug it exactly? Would it go instead of original 18 pin plug? But the smaller 8 pin won't plug easily there as pins in female are too small
Smarttap.
If you’d like, post up pictures of what you currently have for the mod and I can try to help you out.
#83
I actually didn't get any aftermarket turn signal and that is what caused the confusion. I only have the 8 pin and thought I only need to plug it in the place of 18 pin female. I guess I didn't read the thread properly and need to purchase the diode relay
#84
I tried to take a few pictures when I was doing the mod. You can reference the pics here. https://www.clublexus.com/forums/gx-...l#post10246381
#85
gotcha! Once you get the turn signal relay let us know if you have any other questions.
#86
but if you have the obd auto fold in module without the flashing hazards, you will be fine.
#87
Does anyone know if this mode would work on 2014+ model?
This is the relay I bought:
Anyone know what could be the problem?
#88
I actually tried this myself and couldn't get it to function. I just dont think it works with our trucks. I ended up returning it. I wrote up my Diode installs here
[img]data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==
How could some posters here get it to work?
#89
I just got the Diode turn signal relay and plugged it to the 8 ping harness but nothing is working. I have tested every pin connectivity with original 18 pin via ohmmeter to make sure pins are connected and secure but no luck.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Can you take a picture of your current setup and wiring
Take a look at my post from before. There are hyperlinks that have a lot of pictures in it.
