Lane change auto flashing mod completed
#121
Well it seems like ramachar may not be interested in doing this relay harness for us anymore as he has deleted his post about ordering the material and list of people that were waiting... i guess ill have to order my own parts or just tab into factory wires at this point
#122
#123
That being said, it's really easy to make the harness, no soldering required, just get the wires and the connectors (which I've linked here: https://www.clublexus.com/forums/gx-...l#post10590600). I'll do a cleaner write up/how-to right now. Expect it in that thread in 30 min or so.
#124
I've been gettings some private messages regarding selling the harness, but unfortunately that's against forum rules. BUT it's really easy to make the harness, no soldering is needed.
Parts:
Here's the chart I used to match the pins from the 18 pin stock connector to the 8 pin flasher connector:
From @hzhao 's Post:
The numbering for the pins is looking at the female ends.
Here's another photo that could help out with the numbering on the 18 pin connector (ignore the wires folded in half, those are not needed):
I used shrink wrap to make it look cleaner and hold the wires together which was kind of a pain to slip on after putting the pins on the wires. To make your life easier I'd recommend wrapping the wires with electrical tape instead.
Don't know what else to add. That should be able to give you all you need to create the harness yourself. Let me know if I need to clarify anything or if you've got any questions.
Parts:
- 1x Male Toyota 18 Pin Connector (Toyota Part # 90980-11973) https://www.hi-1000ec.com/product/1079
- 1x Female (CF18) Connector (Toyota Part #90980-10799) with female pins https://www.hi-1000ec.com/product/447
- 5x 040 Wires with Male pins: https://www.hi-1000ec.com/product-li...&Submit=Search
- I tried to make the colors as close to the stock wires as possible so this is what I got:
- 2x Green https://www.hi-1000ec.com/product/1262
- 2x Black https://www.hi-1000ec.com/product/1259
- 1x Yellow https://www.hi-1000ec.com/product/1263
- 3x 090 Wires with Male Pins (Ignore the first 2 connectors) https://www.hi-1000ec.com/product-li...&Submit=Search
- What I got:
- 1x Red https://www.hi-1000ec.com/product/1353
- 1x Yellow https://www.hi-1000ec.com/product/1356
- 1x Green https://www.hi-1000ec.com/product/1355
The following 5 users liked this post by Ramacher:
#125
Former Sponsor
Sorry to hear that Ramacher. Sounds like there are still a lot of people wanting this harness to use our SmartTap. I'll see what our team might be able to do to get these adapter harnesses made.
The following 5 users liked this post by Diode Dynamics:
Acrad (02-11-20),
csrpenfab (02-11-20),
HotRod2 (02-11-20),
tecman (02-11-20),
tipsytopsy (02-11-20)
#127
Super Moderator
Does this mod just remove the electric trailer brake circuit or all trailer electrical including light functionality for a non-braked trailer? I guess I thought it was just the electric brake circuit.
#128
If I remember I'll test this weekend. That being said, it's real easy to reach up there and unplug this harness and reconnect the stock flasher relay.
Acrad (02-11-20)
#129
Parts ordered. . . Thanks for the detailed list and updated assembly steps Ramacher!!
Ramacher (02-17-20)
#130
With the collaboration of Ramarcher, I created a step-by-step guide to assemble this harness. With a few basic tools, this thread and a bit of patience this mod can be easily completed.
Here's page 1 as an example:
The following 4 users liked this post by MarkVII:
#131
Heres the photo from earlier
Thanks
#132
FWIW, I believe that diagram photo is looking through the connector from the front. Looking at the back of the connector, PIN 1 is the upper left most PIN.
#133
Please correct me if im wrong lol
#134
I did attempt this mod for my truck.. after buying all parts, confirmed by the dealer today that auto flash is standard on Lexus GX 2020 just needs to be enabled by the dealership. smh.. all the trouble and $$ I spent.. good thing i think I'll be able to return the relay but not the adapter I created.. so if anyone is interested, check out the Marketplace for the adapter.
https://www.clublexus.com/forums/market/945675
Acrad (06-02-20)
#135
Turn Signal Auto Flash
Looks like I finally found a way to add this feature. I wrote to the company and they confirmed it works with all Toyota / Lexus vehicles. Still waiting for a return email confirming the version of the device. I believe it is the regular one. They are based out of Germany and shipping is a little steep but at least it's an option.
*Edit - confirmed it the universal version. The one linked.
https://www.pekatronic.de/en/Comfort...-relay-92.html
You no longer have to worry about your turn signal being on because you forgot to turn it off! The Pekatronic Comfort flasher relay (One-Touch Turn Signal Module) adds a convenient One-Touch feature to your turn signals. When changing lanes or getting on/off freeway ramps, you just "touch" and release the turn signal lever. The signal will flash 3 or 5 times, then quit.
It is programmable between 3 or 5 flashes.
We must warn you... once you get used to this little gadget, you will wish you had one on all your cars!
Our flasher relay is compatible with all Lexus and Toyota cars.
We have many extra instructions for Lexus. For your GX460 two wire colors are not confirmed.
Please check the attached pdf manual and have a look if you have these wires.
The test for these trigger wires is easy. Turn igninition on. Connect a simple test bulb lamp to ground and enter the wires coming from the steering flasher switch.
If you give ground to the wires over the bulb lamp, the flasher will turn right or left. Easy.
