Rear camera grid lines 2010-13?
#61
I’m not sure what the connection looks like plugging into the OEM camera but will I need something like this?
And I know you also mentioned our factory camera system uses 6v power and aftermarkets are 12v, so would I need this converter as well. As you can tell I’m not a techie by any stretch. I may just buy the camera with the grids and take it to a mobile audio store and they can figure out the install
John00 (07-17-19)
#63
Further researching on the dynamic guide lines, it is provided from Park Assist ECU. For US, there are only two versions of Park Assist ECUs available, one is for vehicle with Premier Sound and other for vehicle without. Another interesting thing I found in Techstream, there is a section "Parking assist guidance/Parking asset monitor" section, when I select it, it indicates "ECU not responding, or your vehicle is not support it". I am pretty sure this is where to enable/disable the guidance line. However, it has been "flagged" as unavailable by the system. Since the ECU has two version for different head units, my suspicious is the "flag" is set by head unit within the service menu. Because different head unit do have slightly different configuration on connection and possible output of triggering signals. The current fixed blue lines on back camera could be built into the camera firmware, that is why you have several versions of back cameras available and most of them described as "back camera w/ guideline".
#64
then i cut the wire loop for the lines and connected it into the car and it worked.
that ES system i believe was 12V, I didnt need a voltage converter. Also the connector matched (luck) and it was just plug and play in the trunk with this small round type plug.
the lines are imposed onto the signal at the camera, so if you can see the camera signal you will see the lines unless they are disabled.
theres only one signal going to the monitor
#65
this one says GX. im sure the pics will disappear when the ad is gone so for now:
https://www.ebay.com/itm/TOYOTA-LEXU...-/323073332352
unless someone wants to copy them here?
I would look up your year on here
https://www.lexussouthatlantaparts.com
or somewhere similar to match the part number
dorman 590-641 appears to be a replacement. without lines, but it also has the same connector although with an extension. so these two appear to agree on the connector type
#66
#67
that link was to an oem cam, at least that what it said
the aftermarket also on the second
the oem uses 4 lines, as seen in the pics at those links
maybe this helps
also there could be differences between some vehicles if theres more options, but the cameras should work the same
cv+ and cv- should be camera voltage
gnd connects to the shield which somewhere is grounded, most likely through an ecu
to power a 12v camera you could connect the 12v straight to the camera from the ign after disconnecting the ecu side of the wire (at the camera)
maybe this helps
#68
I’m sure that camera would fit but I think on the thread it was determined the factory camera wasn’t responsible for the grid lines, I think it was the drivers assist ECU or something. The camera I posted earlier has the lines superimposed already. So I’m looking to see if I buy that camera(it’s only like $20) how the connections would work. The back of the OEM camera has like a 6 pin plug receiver. I also posted a 6 pin to RCA wire that would turn the camera to plug and play...unless I need the 6v to 12v inverter.
that was in response to:
so you can see the connection.
you could cut the oem harness off, the aftermarket connector off and solder everything.
#69
im not saying to buy those.
#70
I still have not attempted this mod. I don't think it would be that difficult. It seems I would need a $20 aftermarket rear camera with grid lines included in the camera, possibly need a 12v to 6v inverter and either cut the camera and factory harness and splice together or buy the factory harness conversion pig tail. My only concern would be if the factory camera could be reinstalled if the mod failed to work or I wasn't happy with the results.
#71
#72
If your concern is to get back to the factory camera, your can simply use the after market camera, just tapping the camera video output to V+ and signal ground to V- to the factory harness. Then tapping into the 12v from rear door lock component. If you decided to go back to OEM, just plug in the original harness.
#73
in the other thread (anyone know where?) it was stated that the GX OEM lines are aligned with the mirrors i believe. the aftermarkets wont be.
could still be helpful for those who want to align with something visible on the screen
John00 (08-15-19)
#75
many cameras have adjustable grid lines. these are usually not adjusted with the monitor, they are adjusted within the camera itself. a power cycle sequence is used, then the camera goes through various grid settings, then the power cycle again to store that version. i dont know which cameras do this and which do not
