Rear camera grid lines 2010-13?
#77
an example
https://www.amazon.com/ZSMJ-Waterpro.../dp/B07DC5KXDC
maybe some need to be purchased then tested
#78
that means the aftermarket is designed for 12v. the lexus uses a switched 6v (not PWM). you can either connect to a different 12v source or use a relay/transistor from the 6v to control the 12v.
if i remember correctly the 6v switches on when in reverse, this keeps cameras from being powered all the time in an effort to increase life
theres also 6 to 12 v boost converters (like boost configuration SMPS)
#80
#81
Actually, the 6v to camera is constantly on (ACC controlled) with the camera. Based from my experiences with Beatsonic project and try out of Tesla Style console, the video signal is always available regardless the shift position. The reverse signal only trigging the switch for display.
still need to get to 12v from 6v. theres different options:
direct wire to a 12v source
use a relay, which if the cameras always powered then this is the same as a direct wire
use a boost config SMPS inline. this might be easiest
boost config SMPS example:
#82
I really dont remember anymore. Somewhere when I did my camera work I kept some notes. I thought the power was switched with the shifter to the accessory meter, then that meter powered the camera.
https://www.amazon.com/Converter-DRO.../dp/B01L90B3RI
#83
Are these both basically the same? If so then the cheaper the better I guess. I appreciate both of your inputs and links to purchase on Amazon. The camera gets delivered Monday so I’ll wait for your response on which one to buy. When I have both parts I’ll head to my buddy that is much better at this stuff then me to install, I will post pics. Thanks again.
#84
#85
Ok, so the cheaper one. I know one says step up and the other says step down, that may also be in what direction it’s installed.
#87
I agree, and I’m in the beginning stages of substituting an inexpensive aftermarket camera that has the guidelines incorporated into the camera, with adjustable guide lines. You will also need a 12v to 6v converter due to the OEM setup being 6v.
