Anyone pulling transmission temps via OBD?
#46
Hey, that's me! Had to fiddle with it a bit using the codes provided on the SGII website, nothing too terrible. Had it up and reading temperatures in 5 minutes.
#47
As mentioned earlier the SGII that was previously set up for my 07 GX did not work to read TFT on my ‘13 GX. When you look this up on the Scangauge website, they’ll provide you with several parameters to choose from. The first set I entered did not work. Attached is a pic of the parameters that worked on my GX.
#48
#49
Only you can determine if it’s a worthwhile investment for you. I find this useful for my needs. You can check their website for full details but this functions like a fancy OBC. It can measure fuel consumption, trip data, performance data, and a ton of other parameters I personally don’t care for. What I like to monitor are coolant temp, transmission fluid temp, charging system/voltage, inlet air temp, and the ability to scan for existing or pending codes. I also use this on our other cars if needed.
moose545 (09-20-19)
#50
Super Moderator
No idea how well this one works with 460 but reportedly works with all ECUs on a GX 470. This is a OBD2 wired option.
https://hewitt-tech.com/store/index....ct_detail&p=15
#51
know this is an old thread but wandering if this is the app people are using: https://play.google.com/store/apps/d...hScan&hl=en_US
I have torque pro and elm327 obd bluetooth adapter I've used on previous 4runners....
thanks
thanks
#52
Super Moderator
That is it. If you buy one of their OBD adapters they give you a free app..basically the same called OBD Link.
#54
Super Moderator
Correct. That should work... all the generic ELM327 and I have 5 or so have worked fine with Fusion
i also have one of their adapters since I use with other cars as well so use Link as well
nuclearn8 (03-21-20)
#55
So I can't get my old elm327 obdII mini bluetooth to connect to my phone... forgot the pin code... anyone bought one recently and willing to share recommendation (with link, amazon preferred) for one they know works with the fusion app and our GX
#56
Super Moderator
Might just be 0000, 1111 or 1234
Worth a shot if you haven’t tried them all
