Anyone pulling transmission temps via OBD?
Old 05-20-24, 09:48 AM
  #106
Lagtime
Lagtime's Avatar
I use OBDLink on my '23, selected 2021 during setup. It measures TC and pan temp just fine.
Old 05-20-24, 09:50 AM
  #107
thatwasbrilliant
thatwasbrilliant's Avatar
Excellent. Thank you. I'll give that a try.
Acrad (05-20-24)
Old 05-27-24, 11:35 AM
  #108
thatwasbrilliant
Went on a 12 hour trip from MD to ME (plenty of highway inclines) the other day and watched temps for the entire trip. average engine oil and trans was 195. The TQ went over 200 numerous times, The hottest was 215 while crawling in traffic at 25 mph. Highway was about 195 as well on average.
What is the process to pin the transmission thermostat open?
Old 05-27-24, 01:46 PM
  #109
308guru
308guru's Avatar
Because you know better than the engineering group at Toyota, or what is your reason to do so?
Old 05-27-24, 02:02 PM
  #110
thatwasbrilliant
"Because you know better than the engineering group at Toyota, or what is your reason to do so?"
Useless comment. Why bother? Surely you have better things to do or not??
Old 05-27-24, 04:53 PM
  #111
Acrad
Super Moderator
Acrad's Avatar
Received 3,641 Likes on 2,385 Posts
Please steer back to thread topics.
Even a strong paper clip will pin it open
https://www.clublexus.com/forums/gx-...l#post10845450
Old 05-28-24, 07:09 AM
  #112
thatwasbrilliant
Perfect. Thanks!
Old 05-30-24, 09:53 PM
  #113
ejthomp
ejthomp's Avatar
What might I be doing wrong? I don’t see TC or pan temp as options. I downloaded the Toyota 2021 Enhanced Diagnostics but no extra PIDs are visible.
Guidance appreciated!
Disregard! I figured it out!
Old 07-06-24, 07:45 AM
  #114
thatwasbrilliant
Just got back from the same 12 hour trip, this time it was 95 degrees outside. Steady 200 F on the trans, 195 on the oil and saw as high as 230 F on the trans briefly. This is after pinning the thermostat open before the trip.
leg3ndary
10-18-17 12:41 PM
Chilo
12-14-15 01:51 AM
Boron
02-03-13 12:00 PM
lserlohn
RX - 1st Gen (1999-2003)
06-03-11 03:55 AM
Styx
Performance
07-09-04 12:58 AM
Quick Reply: Anyone pulling transmission temps via OBD?
