Gx460 2011
Old 05-17-18, 01:33 PM
Hanlce
Hanlce's Avatar
Default Gx460 2011
Hello Clublexus members..
Im a new owner of a gx460 2011 with 60k mileage on it, I go it from a friend whom it was 1st owner.
I like it a lot, my take on it is the wear that you can see on the driver's seat leather, and my 2nd q is, " I know ppl went over this before" about the gas mileage, any way I can get better mpg? I live in California, can I use 87 gas instead of the pricey 91 premium? Any real damage to the engine might happen?
Thanks .
Hanlce is offline
Old 05-17-18, 02:00 PM
bbqsoup
bbqsoup's Avatar
Welcome to CL
There's a lengthy discussion on the gas subject in the thread below
https://www.clublexus.com/forums/gx-...ny-issues.html
For short term, there shouldn't be any damage to the engine as it is designed to retard timing for lower graded fuel. However, no one knows the long term affect. You may try to run a few 87 tanks in yours to see if you can feel it.
Which part of CA you're at?
bbqsoup is offline
Old 05-17-18, 11:24 PM
Hanlce
Hanlce's Avatar
Originally Posted by bbqsoup
Welcome to CL
, thanks Im Sacramento.
Hanlce is offline
Old 05-21-18, 07:45 PM
cruzinZ
cruzinZ's Avatar
Fill up at Costco for less expensive fuel. The engine was designed to run on 91. Putting in a lower grade will retard the timing & will decrease the amount of power the engine produces. Is saving a couple dollars per tank worth the risk? Personally I think if you are trying to cheap out and regurally put in lower grade fuel you are driving the wrong vehicle. May I suggest a cheap beater car for commuting that requires 87?
cruzinZ is offline
Old 05-23-18, 04:23 AM
situman
situman's Avatar
I wouldnt get gas from costco if I were you. I ran a tank of that stuff and it killed my gas mileage and made my ES350 run like crap. Yes low grade gas affects gas mileage believe it or not.
situman is offline
Old 05-23-18, 03:44 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,652 Likes on 2,391 Posts
Might be a regional thing... I use it in all of my vehicles and haven't noticed any ill effects. We get most of our oil from Alaska and processed through local refineries
Acrad is offline
Old 05-23-18, 04:03 PM
hzhao
hzhao's Avatar
Same here. Costco at my area sale 93, and I have been using then since day one. No issues.
hzhao is offline
Dmaxdmax
RX - 3rd Gen (2010-2015)
05-13-19 07:56 AM
islandbeef
09-26-16 10:48 AM
WES350
ES - 5th Gen (2007-2012)
01-03-15 12:54 AM
SteveKnows
CT 200h Model (2011-2017)
03-02-14 01:53 PM
Bonty2011
Hybrid Technology
78
06-25-12 04:35 PM
Quick Reply: Gx460 2011
