GX 460 Shift lever locked on P
Emergency lights are working. Its only possible to switch gears when you press button in the upper left.
Any solution to fix ?
Not sure what you mean by "emergency lights are working".... There could be several possibilities. First thing I will check is the the switch assembly right above the break pedal where linked to the break pedal arm. If it is malfunction, it will inter lock the shift.
As hzhao said check the brake light switch. In the meantime:
