Error code 2432, over-ride Limp Mode?
Wife's 2011 Lexus GX 460 went into limp mode with the traction warning light, check engine light, and flashing 4-Lo. Our local mechanic tells us error code 2432, and that he can't fix it. Apparently this is related to the secondary air pump system. I removed the pump cover to see if the filter had been sucked into the intake (a reportedly common issue), and instead found the filter element sort of dissolved into a blob, which I scraped out with a screwdriver. I saw no evidence that anything had gotten into the intake, checking a valve and hose.
So Wife made appointment with the nearest Lexus dealer in Santa Fe. At 75mph, Santa Fe is a 2-1/2 drive. It's a busy interstate, no way safe to drive at 40-50mph.
Is there a way to over-ride the limp mode long enough to drive safely to the dealer? I've tried unplugging the pump and valves, and disconnecting and reconnecting the battery.
Any insight is appreciated!
Super Moderator
tecman was able to get it out of limp mode by unplugging the air pump.. not sure if a code reset with an OBD reader is needed first even though it would be re-triggered right away
How? I unplugged the battery for an hour...
I doubt they'll go for that. We bought the vehicle used at a different dealer...
If that doesn't work, since this issue is under an extended warranty, I'd make the dealer come and pick it up at theirs or Lexus expense.
I unplugged the air pump wiring harness, and even disconnected the battery after. No change, still in limp mode.
Bobthearch (05-25-18)
The car is stuck in Limp Mode. It is not safe to drive at 40mph to the nearest dealer, which is a 2-1/2 hour drive on a 75mph interstate.
The codes have to be cleared to get it out of limp mode and unplugging the pump prevents it from going back into limp mode
The following 2 users liked this post by tecman:
Acrad (05-25-18),
Shouldn't any obd2 code scanner be able to clear this code or do you specifically need techstream?
An obd2 scanner you can pick one up pretty quickly and easily for $15-20 at wal mart pep boys autozone etc.
But is there no way to clear or reset the codes so we can drive the car to the dealer today?
Ah-ha! A new plan. Can a regular Toyota dealer do this? It's only 20 miles over a mountain interstate pass. But with the safety blinkers on, I think that would be reasonably safe, at least less suicidal than driving to the Lexus dealer.
Will that work for resetting the code, or just reading the code? We happen to have an Autozone in town...
Super Moderator
Standard OBD reader purchased anywhere can clear these emission related codes.
Goto that Autozone.. they might even do a clear for you without purchase.
