Radiator Questions and Comments
Old 01-14-20, 06:49 PM
  #31
JonGX
JonGX's Avatar
Originally Posted by jpcdmd
My '14 has a radiator leak, slow drip, was down about 1/2 gallon at my last oil change. Quoted $980 for the repair using OEM parts, including new upper and lower radiator hoses. Debating whether to tackle it myself. Sounds like a pain in the ***. Worth it?
do you see dried flaky pink coolant anywhere in the engine bay?
Old 01-14-20, 06:55 PM
  #32
Ramacher
Ramacher's Avatar
I got a very similar quote ($980) from Clear Choice Independent Lexus in Houston. Was in a hurry and decided not to leave the car with them. Next morning leak was worse, went to a shop closer to my apartment and stupid me told them the previous quote I got. They basically charged me the same thing ($450 for radiator, rest was labor) they didn't even change the upper+lower hoses, charged for antifreeze+flush and I can't even verify if they truly did a flush. Guy said he'd use "japanese" radiator, don't know why he kept repeating that., i just interpreted that as OEM. A month or so later I was poking around the engine bay I found out he used a Denso which sells on RockAuto for $150. Still pissed off about it. Should have gone with Clear Choice Lexus where they would have used OEM, flushed the antifreeze, and replaced the upper+lower hoses.
Old 01-14-20, 07:28 PM
  #33
drnls
drnls's Avatar
Just did this on my wife's '13 . It is quite a bit of work, you have to remove the front bumper cover . I drained the block, replaced the water pump and tstat along with upper and lower hose . If you have the tech doc it walks you thru really well .
Old 01-14-20, 07:30 PM
  #34
downshift1
downshift1's Avatar
Originally Posted by bbqsoup
A radiator is $160 as posted from downshift1, but it's after market. 2-3 gallons of pink coolants is $20+ each so that's $60+. If you go to an independent mechanic it's probably about 2-3 hrs labor, roughly $400-450 charge.
If you're not comfortable doing it, I'd let the dealer do it if they replaced the hose and use OEM parts.
If you do it yourself, when you remove the fan, shroud and bracket, you may also want to replace the fan bracket too with that mileage while you have it out.
​​​$160 is a Denso unit just like factory
Old 01-15-20, 05:23 AM
  #35
Acrad
Super Moderator
Acrad's Avatar
Received 3,641 Likes on 2,385 Posts
Make sure it isn't the water pump as well. Several of us here have experienced that issue including myself.
One of my biggest concern with parts these days are all the counterfeit parts on the market. They even put similar OEM labels on them. A real gamble on whether a long term fix or a near term headache. On the jobs I don't want to do again anytime soon I am willing to throw some extra money at increasing the odds I have a high quality part.
https://www.worldtrademarkreview.com...er-safety-risk
In addition... even legitimate parts makers often have differing lines of parts with varying quality/durability as well as the associated costs.
The following 2 users liked this post by Acrad:
cb1111 (01-15-20), Chasin (02-19-20)
Old 01-15-20, 07:48 AM
  #36
cb1111
cb1111's Avatar
Very astute observation. We work with a market leader in anti-counterfeiting labels and we've been approached by several automotive corporations to create labels for their products and packaging. If we think the problem is bad here, then you need to look at third world countries (or Amazon ) where most products are fake.
In all seriousness, the number of counterfeit items on Amazon is staggering. Batteries and spare parts are great targets for counterfeiters.
Old 01-15-20, 08:27 AM
  #37
jpcdmd
jpcdmd's Avatar
It's the radiator, not just a hose. The tech sent this pic.
Old 01-15-20, 08:28 AM
  #38
jpcdmd
jpcdmd's Avatar
Is there a link to the tech doc online?
Old 01-15-20, 09:20 AM
  #39
Romanova
Romanova's Avatar
I used Clear Choice in the Woodlands for my GX when the radiator went south last year. OEM radiator, hoses, clamps, and coolant. About $950 but worth it as I was short on time.
texas008 (02-20-24)
Old 01-15-20, 11:37 AM
  #40
JonGX
JonGX's Avatar
THIS^
I have heard this mentioned many times in the Toyota world (I have an old 4Runner) and have experienced this myself - specifically with brake products, alternators, and starters. Buying an OE part from the dealer vs. buying what you would assume to be the SAME EXACT part from the original manufacturer (OEM) doesn't always end up with the same level of quality. I think it's common for vehicle manufacturers to specify a very specific quality/tolerance level for the parts that they buy (e.g. brake disc runout) . Parts that don't meet the automakers tolerance level but still meet/exceed functional testing requirements by the part manufacturer are sold to auto parts stores and other retailers (e.g. RockAuto) for sale to the general public. The buyer thinks they are saving a bunch of money by buying the same part as they could get at the dealer, but they end up potentially getting a lower quality part. This is why I stick to buying Toyota parts for critical repairs (brakes, suspension, cooling) and use aftermarket items for less critical things.
SteveInCal (01-17-20)
Old 01-15-20, 01:11 PM
  #41
jpcdmd
jpcdmd's Avatar
It's going in tomorrow. I'm not feeling up for a messy job by myself just to save $500. I was incorrect on the quote, it's actually $930, not $980.
Old 01-15-20, 01:19 PM
  #42
JonGX
JonGX's Avatar
that pic is a little small, but it does look like the leak is starting up where the aluminum part of the radiator meets the plastic sides.
Old 04-17-20, 05:16 PM
  #43
dclaytor
8th Gear
dclaytor's Avatar
Default 2013 GX460 Radiator Leak
Long time lurker here, do majority of my own maintenance. Wife mentioned something leaking under our GX last night after braving the elements to get food, and sure enough radiator is leaking near top hose / cap. This seems to be the common failure point between aluminum and plastic components, but wanted to see if any feedback here before I start ordering away:
Old 04-17-20, 05:58 PM
  #44
Lavrishevo
Lavrishevo's Avatar
I would not be scared. The radiator itself is not expensive. Amazon has it too but for $192
Old 04-17-20, 06:12 PM
  #45
ASE
ASE's Avatar
Received 1,028 Likes on 686 Posts
Per earlier response ... check to see if the tank is actually weeping versus at the radiator hose. Yes, the seal between the plastic and aluminum is a common failure. Do yourself a favor and buy a Lexus (OEM) Radiator ... not an aftermarket ... replacement is a hassle, so not worth the savings for less than original Lexus parts. Search Lexus dealerships on the internet that offer wholesale pricing, free shipping and no sales tax ... 30-40% less than over-the-counter retail pricing at a local dealership.
Quick Reply: Radiator Questions and Comments
