Backup #camera #washer 😉
Old 05-12-23 | 02:24 AM
  #46
Vitalium's Avatar
Vitalium
4th Gear
Hi
In Ebay now available camera washers for GX with around view https://www.ebay.com/itm/225551114200 and GX without Around view (only rear camera) https://www.ebay.com/itm/225510967634
Acrad (05-12-23)
Old 11-13-23 | 08:15 PM
  #47
chris1973s's Avatar
chris1973s
Default Rear view camera washer
Looking for a washer mod on the rearview camera of 2023 GX i found some for older models 2013-2018 not sure why they wouldn't work on 2023 but after contacting the seller, he confirmed no fit on 2023. Not sure what changed between the years, but I live in a snow country and a washer would come in handy. Anybody installed a washer on 2023?
Old 11-13-23 | 08:41 PM
  #48
John00's Avatar
John00
they have aimable windshield washer nozzles. like 10$
Old 11-14-23 | 07:05 PM
  #49
chris1973s's Avatar
chris1973s
ok, where and how would you install it?
Old 11-14-23 | 08:18 PM
  #50
John00's Avatar
John00
amazon sells them. theres different types. you can get one you drill a small hole, mount it, run a hose from it to a tee in line with the rear wiper hose. the nozzles usually have a small brass orifice you can loosen and adjust.
Old 11-15-23 | 06:27 PM
  #51
chris1973s's Avatar
chris1973s
good tip I'll look into that, Thanks
Old 04-11-24 | 05:42 PM
  #52
gx23owner's Avatar
gx23owner
5th Gear
is it any different from 2022-2023 model?
Originally Posted by Acrad
Old 04-12-24 | 12:52 PM
  #53
chris1973s's Avatar
chris1973s
Default camera washer
Yes, i called them was told it does not fit 2022-2023
gx23owner (04-12-24)
Old 04-12-24 | 01:04 PM
  #54
gx23owner's Avatar
gx23owner
5th Gear
Did you find any alternative for 2023?
Old 04-12-24 | 02:03 PM
  #55
chris1973s's Avatar
chris1973s
Unfortunately no which sucks as i live in a snow belt and i could use it for sure
Old 04-15-24 | 12:28 AM
  #56
gx23owner's Avatar
gx23owner
5th Gear
I was looking at the rear camera of the models before and after 2022 and I don't see a difference. I am not sure why the seller said it won't work.
Old 04-15-24 | 06:35 PM
  #57
John00's Avatar
John00
i did email them on the 2012 but got no response.
Old 04-16-24 | 08:00 AM
  #58
hzhao's Avatar
hzhao
Just because it looked no difference from the outside, the camera itself and mounting hardware, harnesses can be very much different behind. That is a common occurrence as manufacturer switch different suppliers from time to time.
Old 04-17-24 | 10:35 PM
  #59
gx23owner's Avatar
gx23owner
5th Gear
I agree with you. I looked at the original backup cameras of models 2018 and 2022 and I see a big difference, which means the aftermarket bracket with washer for 2018 won't work for 2022-2023.
tabjohitol
08-14-20 08:18 PM
phildogbph
GX - 1st Gen (2003-2009)
07-06-20 10:17 AM
1halifax
NX - 1st Gen (2015-2021)
10-19-15 06:55 AM
LX570Power
LX - 3rd Gen (2008-2021)
01-26-10 05:40 AM
Aristo300
General Classifieds
05-22-08 06:47 PM
