auto engine start GX460 Luxury
I recently purchased a 2015 Lexus GX460 Luxury package. wondering if it comes with auto engine start. Ive tried the recommended Lexus Key Fob with no luck. Ive heard that I need to contact Lexus to have the fob paired with my phone? its $8.00 a month or $80.00 a year
does anyone have any experience with this?
excellent info thanks.
will they send me a new remote? or can I use the existing remote? forgive my ignorance I could hardly understand the woman at Lexus customer service. I'm confused on how they are able to program my fob for the auto engine start feature.
Thanks again
Thanks again
not true. There were 2 remote start modules made for the 2015. There was one where you could only remote start the car with the key fob. There was another one where you could again use the fob but then you could also remote start via an app. The use of the app to start the car costs the $80/year. If you chose not to pay the $80 you could still start the car with just the fob.
Hi Pinoyesv6
Thanks again for such good intel.. I have 2 fobs that came with the car, both of those fob would already have to have the remote start on the fob correct? Neither FOB at this time is able to start the car remotely, I Joined lexus Eform and waiting til the open at 0800 to speak to a rep.
Will they be able to program my FOB free of charge if it was originally designed to have a engine start?
Thanks again
1SG
OUT
Thanks again
1SG
OUT
Hi Pinoyesv6
Thanks again
1SG
OUT
Thanks again
1SG
OUT
This is the FOB based unit I installed in my '12.. claims to work through '15.
PN: PT398-60112
https://www.clublexus.com/forums/gx-...ine-start.html
PN: PT398-60112
We also have a 2015 Luxury model and I searched for a way to use a remote start with no luck. My 2015 GS350 has it via the Enform App, so I assumed a 2015 GX would have it too. After much searching and a trip to the Dealership (talked with two seperate people and both were Lexus "Geniuses" ) no dice! The 2015 models seem to fall into a purgatory of sorts. Too old to work with the Enform App (was told it was not compatible - at all) and the RES unit has been discontinued for quite sometime.
If you find out otherwise, please let me know.
One can still buy the RES unit if one wants to install. I only paid around $100 for mine but here is an example on eBay.
https://www.ebay.com/itm/LEXUS-OEM-F...2/331826471697
My $.02. My '14 Luxury has remote start that is operated by the key fob only. Press twice then press and hold. Sometimes it doesn't work and the sequence must be repeated. I think timing of button presses has to be fairly precise. It has a short effective range, and is easily defeated by obstacles. Also, the engine shuts off the moment you touch the door handle. I have a different vehicle with remote start via the key fob (a Mopar). It is a far superior system with simpler, more reliable operation and much longer range. I rarely use this feature on my Lexus.
