Brake Issues/Problems/Questions
#213
Possible to buy, with crazy price...
https://hardbrakes.com/index.php?main_page=index&cPath=6_1348
Or made by your self.
Material titanium plate 1.0 mm , I buy with price 5$ & one hour in garage 😉
#214
What temp differences are you seeing and more importantly on the given day what are average brake distances with and without said air scoop?
I would wager this would only help those who are continuously on the brakes with a trailer or navigating frequent high speed stops. Regular driving the amount of airflow would be adequate as brakes even on porsches dont see the temps you would see with whats needed in vehicle with brake ducting
#215
I made big upgrade of brake system.
- Install new DBA T3 brake rotors. More better material.
- Fabricated new stainless steel custom - made pistons with ventilation holеs ( fwd & aft ). Actually when driving a car on water obstacles.
- Use of SPECIAL lubricants for the brake system ( Not original from Toyota / Lexus ). Better keep high temperatures.
- Custom- made brake hoses, also more stronger.
- Titanium brake pads shields. To prevent overheating of the brake cylinders.
- Install additionall air flow flaps. More cooling.
- Ceramic brake pads original from Toyota / Lexus.
Now my car is ready to brake in any situation under any driving style.
It took a lot of time to experiment and measure of temp.
Of course, if you use your car for driving from home to the supermarket and to work, then you do not need it.
#216
Thanks a lot for your tips. Could you explain it a little more as I never heard of that before. If i try to double press my brake at a stop, the moment I take off my feet after the first press- the car jumps forward. How do you do this double press? Any documentation or video link? TIA.
#217
It was my Mercedes, but I wish the GX had it. One of the only features I really miss about that car. Basically, when I came to a stop I could pump the breaks one more time (press down harder) and it would hold until I hit the gas. Which is a much better system than on the BMW's I drove, that sucked in the brake peddle every time you stopped.
#218
Useful some times.
#219
applied. One instance is when you want to do some brake job, first thing to do is releasing the brake using a tool connected to OBD port. Lot of cars feature and options are via implementing electronic
technology in conjuction with mechanical. Without basic electric/electronic knowledge working on new cars become quite difficult and dangerous. Many old school tech. does not even know which way
current flows in a diode.
#220
If you're at a point to which you feel safer putting the driver select to neutral, I suggest you check out what pads are on it.
I understand what you mean and I too have to essentially "double brake" once I come to a stop. My previous GX did this and so does the new one.
I had it checked out with the master tech and he says it's very normal for this vehicle.
#221
What makes LX brake spec. different from others? I think brake hold is electronic function. On the side not regarding brake if you never had Audi. When Audi is parked and engine shut off brake is kept
#222
Super Moderator
Resurrecting old thread before my time here... just an FYI video I found. I changed mine last year.
Beachy (03-09-19)
#223
This is on my short list. Going to do rear pads and rotors. I'm sure my rotors can be turned, but I really like Centric Premium rotors that have the hat painted black. Just gotta' wait for the weather in Houston to cool down a bit first...
#225
Super Moderator
I haven't noticed that on my GX but not uncommon these days on vehicles with EBD. Many try to leverage more additional rear braking when possible.
Mine were pretty much even wear all around when I changed mine last year.
