Sorry..not sure....All I know is that adapter(s) need a legitimate 2.x ELM chipset. You may need to reach out with vendors or companies directly to confirm. Make sure whoever you buy has a good return policy if claim ends up being bogus and it doesn't work.
I believe the veepeak is probably a clone ELM137 chip so it won’t display TPMS info.
It will work with ODBFusion to pull all other data though.
It has 1 year warranty so you can give it a try.
I purchased the Bluetooth Android elm327 module from Elm-327.eu. Am unable to find the individual tire pressure pid. The only PID I can find is tmps status and tire pressure monitor on/off. Using obd fusion. Any assistance would be appreciated.
Found it under toyota/Lexus. Will try if it displays data tomorrow.
I have purchased the extra option. When the unit is not connected I can add the dasboard for each tpms. Once it connects nothing updates. And if I try to add, there is no option. 😥
Interesting.... anyone else with Android and similar adapter? I have Android devices but would have to drop another $20 to test. BBQSoup and I have IOS.
4les: You might want to email OBD Fusion Support and see what they say. Link this thread as well.
When first launched, did you see a choice to connect ODB Fusion to TPMS Module instead of Generic OBDII or Network A? Like the screen shot that Acrad posted.
would someone please share what exactly I would need to purchase to be able to read TPMS data? I currently am able to connect TS to both my 2016 GX460 and 2015 Tundra, but would like something that I can access more on the go. I use iOS. Thanks in advance!
Once you have adapter and Fusion you will want to connect to the car so you can purchase the Enhanced Diagnostics package for both your GX and Tundra. Base OBD Fusion is $9.99 and each model year expansion pack for each vehicle is $9.99.
Within OBD Fusion goto SETTINGS --> PURCHASE EXTRAS
to obtain the Enhanced Diagnostic packages. They are in-app purchases.
Long story but the inspection shop broke the tpms sensor on a GS350 wheel. I have some Lexus GX460 sensors that I was planning on using the the new set of SCS wheels. I also just ordered some sensors that are OEM to the GS350. I was wondering if I could use the ones for the GX since the newly ordered ones might not be here for a week.
