TPMS / TPWS Questions/Comments/Concerns
#331
Super Moderator
Sounds like you may need to complete a few drive cycles
#332
Yes, I have done the above several times.
However, I did notice that the tire pressure warning light DOES NOT blink when I did the calibration process. I held the button for a good while too.
I think a trip to the dealer is in order now...
Thanks!
Thanks!
Acrad (10-06-21)
#333
Super Moderator
#334
Super Moderator
I added this... for whatever reason that elbow piece on mine had some obstruction and wouldn't pass air pressure properly... just hooked up the air hose and that will work well enough for me. For the price wasn't gonna bother with an exchange.
Remember 10-19 owners... you can read TPMS pressure via OBD Link
https://www.obdlink.com/support/mxp/
https://www.clublexus.com/forums/gx-...and-gx460.html
'20+ for those that don't know can read PSI on the dash
Video
Slprciv (10-11-21)
#335
2019 GX460 - does spare tire have a TPMS ?
Hi! I am wandering whether the spare tire has a TPMS sensor? This can save me some $$$ today if my tire shop does not have to take a tire out to investigate.
Many thanks in advance,
Mike
Mike
#336
Super Moderator
Yes.. and no way to single it out and exclude from TPMS. TPMS... is all 5 tires or none.
mikezat (12-17-21)
#337
On the bright side...you have a full size full duty spare!
#338
TPWS pressure warning setting…can it be changed?
The door sticker shows 32PSI but the tires I have on now should be 35PSI.
It dropped in temp locally and I just had the warning light come on for a tire at 34PSI.
Could the dealer have changed the minimum pressure when I took it in for service a couple weeks ago?
#339
Yes, just follow the "Initializing the tire pressure warning system" instruction in the owners manual (page 473 in my manual)
jlficken (05-21-22)
#340
I never noticed this nugget of info in it:
When the tire pressure warning system is initialized, the current tire inflation pressure is set as the benchmark pressure.
#341
I bet it happened because they moved the spare to the passenger rear but didn’t drop the pressure from 45PSI so I lowered it down to 37PSI but it was only after I reset the TPWS as they didn’t reset that either so the tire locations were all messed up. Since it thought the normal temp was 45PSI it tripped at 34PSI.
jlficken (05-21-22)
#342
TPMS/TPWS tool choices?
I’ve had it with the local tire store after todays fiasco with getting a spare fixed on the wife’s RAV4 and refuse to take a vehicle back there. They also said the 2 y/o OEM sensor in the spare wasn’t working so they replaced it with a generic sensor which I’m not thrilled with.
Since the Lexus dealership couldn’t manage a 5-tire rotation either I will start doing these things myself.
What’s the best option out there for OEM Toyota/Lexus sensors so that I can activate a new sensor to the vehicle as well as change positions?
I need to be able to activate/assign a new OEM sensor as the RAV4 only accepts 4 of them and I have a full size spare with sensor in it so I’ll have to do this every rotation unlike the GX which accepts 5 sensors.
Would the Autel TS508 be a good option or would I need something else?
2022 GX 460 and a 2019 RAV4 are the vehicles in question.
#343
Check your manual on TPMS Registering ID codes, I didn't need anything to change over my winter to summer tires, Just followed the register ID codes (page 475 in my 2021 manual) and then "How to initialize the tire pressure warning system" (page 474) No special tools required
#344
I don’t think I can test a sensor without a tool though that I can think of?
IanG (05-24-22)
#345
I use techstream to program the car to my different sensors. i have a notepad file with the sensor ids in it so i don't need to check all the time.
the stupid place I got my second set of wheels from couldn't tell me the IDs for my new sensors so I ended up buying an Autel TS401 to read my sensors and give me basic readings. I use it now to check my tire pressure without depending on the light.
