TPMS / TPWS Questions/Comments/Concerns
Old 07-06-23, 07:36 PM
  #421
Acrad
Super Moderator
Acrad's Avatar
Received 3,655 Likes on 2,393 Posts
Just checking… Did you check pressure on spare as well? There are 5 sensors.
Old 07-07-23, 05:12 AM
  #422
m5rahul
m5rahul's Avatar
Yeah, I did. Wasn’t fun dropping the spare for it .. should’ve done the valve stem extension mod ( as shown by GX Bob ) but alas..
Old 07-07-23, 05:14 AM
  #423
m5rahul
m5rahul's Avatar
Originally Posted by IanG
On my 2021 I can program new TPMS sensors and reset the pressures through the small dash info screen and the steering wheel navigation buttons. I do it with seasonal tire changes and it works great. Not sure if your 2018 also offers this but check your manual to see
The pre ‘20 models don’t have this ..
IanG (07-07-23)
Old 07-07-23, 05:28 AM
  #424
Acrad
Super Moderator
Acrad's Avatar
Techstream or OBD Link you could pull the codes and/or pin down the failed sensor.
https://www.clublexus.com/forums/gx-...stic-tool.html
Assuming it is just one bad sensor you could change pressure in each tire to track down which sensor has failed or is giving erroneous readings.
Unlike 20+ you have to sleuth for a defective one on 10-19 models
Old 07-09-23, 05:41 PM
  #425
m5rahul
m5rahul's Avatar
Okay so I figured I’d do the TPMS delete that GX Bob posted on YouTube and well.. turns out my GX (2018 : Premium ) doesn’t have the Red TPMS box ( at least not in the location shown by GX Bob!! )
GX Bob’s video link :
My video link :
https://youtube.com/shorts/6B0_Kov7ElE?feature=share
All that prep and work in 100 degree weather for nothing! 😡
So, got a few questions.. 😊
- Was /is the TPMS module optional ?
- If it’s standard, could it be located in a different place ? Anyone know where ?
- If it’s optional, could the TPMS light still come on ( not sure how but.. ) ?
Plz chime in! Thanks..
Piney1 (01-31-24)
Old 09-22-23, 05:44 AM
  #426
Acrad
Super Moderator
Acrad's Avatar
Not surprising with age but appears one of my TPMS sensors is finally dying after 11.5 year. One is starting to send off intermittent connectivity codes and triggering the light. My winters with far newer sensors go on in a month. I need to replace tires in the spring due to age so will replace all sensors including spare (need a new spare tire too).
Old 11-10-23, 06:34 AM
  #427
razerface
10th Gear
razerface's Avatar
Default Tpms readings by tire position
I have the pic of car with tire pressure showing by front right, front left, ect, on dash. When you rotate the tires, does the car know where you put each tire and report tire pressure in correct spot on the pic?
Old 11-10-23, 06:38 AM
  #428
IanG
IanG's Avatar
On 2021 and newer GX you can identify & calibrate the TPMS sensors through the dash/steering wheel controls. The procedure is in the manual
Old 11-10-23, 08:10 AM
  #429
razerface
10th Gear
razerface's Avatar
Mine is 2020. Thanks for the reminder to put that in my signature. So you think mine has incorrect positions on the dash?
Old 11-10-23, 08:36 AM
  #430
IanG
IanG's Avatar
Not sure, if there is a noticeable difference in pressure showing on the dash I would just check the pressures with a gauge to identify the locations
Old 11-11-23, 08:29 AM
  #431
lexo98
lexo98's Avatar
It says to relearn after rotating tires. Here is the procedure. It’s on the bottom of the page
https://www.dillvalves.com/wp-conten...RL-A1260-2.pdf
Old 11-11-23, 10:10 AM
  #432
mike202
mike202's Avatar
Procedure is here from OM.
Hrocks (11-17-23)
Old 11-11-23, 05:00 PM
  #433
mikescool
10th Gear
mikescool's Avatar
I have a 2023 GX and I just replaced all 4 TPMS in my winter rims with brand new ones (Part # 4206753020). I've been driving around for at least 2-3 hours in total, on and off the highway, following the instructions below. It's stuck on registering the sensors screen... I'm not sure what else to do, should I just overinflate and deflate the tires to see if that'll activate them?
Old 11-11-23, 05:16 PM
  #434
IanG
IanG's Avatar
This is for my 2021, when changing wheels it is a two step process. you need to register the TPMS sensors first
Then you need to initialize them
I use this method twice a year swapping winter & summer tires, has always worked for me.
The following 2 users liked this post by IanG:
Hrocks (11-17-23), mike202 (11-11-23)
Old 11-11-23, 05:23 PM
  #435
mike202
mike202's Avatar
Page 491 in OM.
The following 2 users liked this post by mike202:
Hrocks (11-17-23), IanG (11-11-23)
fantic
GX - 1st Gen (2003-2009)
10-09-14 06:33 AM
Defratos
IS F (2008-2014)
22
04-19-14 01:50 AM
zippinbye
18
10-08-13 11:19 AM
HTSHOW
05-03-12 02:14 PM
Deros
CL of Hawaii
02-01-12 11:52 AM
Quick Reply: TPMS / TPWS Questions/Comments/Concerns
