Phone/Tablet mounts
Old 08-31-19, 04:28 PM
  #46
tecman
tecman's Avatar
I have always been concerned with sticking anything to the dash. I use the vent clip to keep the phone up to a better line of sight. iPhone X with a thin cover with the metal plate inside slides around a bit on the mount but still pretty good.
https://www.ebay.com/itm/REDOVER-Car...72.m2749.l2649
Old 01-13-20, 07:39 PM
  #47
Dazed
Dazed's Avatar
This is the best mounting I have seen so far for the GX. After a bit of use, how has it worked out? On my FJ60 and my Tacoma, I used RAM Mounts that were similarly attached to the dash to mount the phone and tablet.
Old 01-13-20, 07:45 PM
  #48
Dazed
Dazed's Avatar
Does anyone have any other solutions for phone mounting? Has one drilled through the dash cover and added a RAM mount ball or such?
Old 01-13-20, 09:01 PM
  #49
csrpenfab
csrpenfab's Avatar
I have an adhesive “NATO Mounts” magnetic mount that also allows wireless charging. The metal plate that adheres to the phone is a ring, so it still charges. I’ll get a pic tomorrow. I got mine on Black Friday for $20, $39.95 now. Works great and I mounted it below the CD player.
https://www.natomounts.com/wireless-...xoCjigQAvD_BwE
Old 01-14-20, 08:07 AM
  #50
xplorr
xplorr's Avatar
I am still pleased with the setup. I only put the iPad in place for off-road journeys, but I use the phone mount all the time. As previously noted, there is some flex to the speaker grill, but positioning the phone landscape orientation with weight resting on the dash makes that a total non-issue. If you want the entire weight of the phone held by the arm and track, it would bounce around quite a bit. Also, especially for the iPad, I had to disable "shake to undo" in iOS while off-roading.
Old 01-14-20, 10:38 AM
  #51
jpcdmd
jpcdmd's Avatar
IMHO, these magnetic vent mounts can't be beat. Holds my phone securely with the metal plate installed under my phone's cover. The mount is small and 1-piece, and has no suction cups or adhesive pads, so I can easily just grab it from the car, toss it in my suitcase and take it with me on vacation to use in a rental car. I have it inserted into my GX's center left vent. When it's mounted, the phone doesn't get in the way of any of the controls on the dash, unlike many of the other designs I've seen. It will slightly block the "AUDIO" button for the nav screen but I can easily rotate the bottom edge of the phone out of the way with the flick of my finger to get to the button, unlike fixed mounts where the mount and/or phone won't move or pivot.
Magnetic Vent Mount Magnetic Vent Mount
Old 01-14-20, 10:46 AM
  #52
bbqsoup
bbqsoup's Avatar
I have used the same one jpcdmd posted above and it works good.
But now I use this one. It put the phone a bit out from the vent
Amazon Amazon
Attached Thumbnails Phone/Tablet mounts-vent.jpg
Acrad (01-15-20)
Old 01-14-20, 06:49 PM
  #53
BlueOnyx
BlueOnyx's Avatar
I use the NILLKIN Car Magnetic QI Wireless Charger II (model A) (FAST Charge) on the vent. I would only get it if there is a matching Nillkin Magic Qi wireless charger case for your model phone. It is a good holder if you have their case. It likely won't hold you phone if you are off roading but in town, it charges you phone when you place it on the stand. Great is you are using power hungry apps live navigation or streaming.
Old 01-14-20, 07:29 PM
  #54
Dazed
Dazed's Avatar
That's good to know that you still enjoy it and that it is solid for offroad use. Did you look at placing the track on other places of the dash that may not flex as much? I am thinking that it may just be hard to access. Also, I'm an android guy, so no shake to undo!
Old 01-14-20, 07:40 PM
  #55
Dazed
Dazed's Avatar
Thanks for the advise. I do want a solid offroad mount, so I am not sure that the magnetic mounts will work. I do like the induction charging though.
Old 01-15-20, 04:35 AM
  #56
JALinker
JALinker's Avatar
Has anyone tried this:
https://www.tacomaworld.com/threads/...holder.372250/
Old 01-15-20, 08:10 AM
  #57
csrpenfab
csrpenfab's Avatar
That A pillar mount is pretty slick, but I'd be a bit concerned I might have a ram mount/phone head-shot in the event of an accident that triggers the curtain airbag.
Chasin (01-15-20)
Old 01-15-20, 01:47 PM
  #58
Chasin
Chasin's Avatar
I'm with this guy... we have curtain airbags there so I would'nt try to mount my phone there.
The following 2 users liked this post by Chasin:
csrpenfab (01-15-20), Piney1 (03-16-21)
Old 01-15-20, 01:54 PM
  #59
JALinker
JALinker's Avatar
Tacos do too--I wonder how they fare?
Old 01-21-20, 02:22 PM
  #60
Joeytucson
Joeytucson's Avatar
Default iPad mini 4 fits perfectly
Originally Posted by xplorr
Shopping list
Install hinges to cover with 3M mount strips
Add rubber bumpers
Install hinges to dash with 3M mount strips
iPad installed
Center dash console access (you can also see a third bumper I installed toward the top to eliminate some minor rattling at the hinge pins)
The following 2 users liked this post by Joeytucson:
Acrad (01-21-20), OCGX (01-21-20)
Quick Reply: Phone/Tablet mounts
