Phone/Tablet mounts
#121
ProClip. They have a great ecosystem of base plates and phone holders, the base plates being custom for each vehicle. https://www.proclipusa.com/vehicle/d...gx-series/2021
#124
I have a suction mount down on the little sliding cover for the CD player. Shifter bumps into it from time to time, no big deal. Not great for eye level though.
#127
cup holder phone mount is the best solution i found so far.
#128
If you have one of the newer “mag safe” iPhones, this mount works great. Phone will not come loose at all and it holds solid, even with a leather case. No need for metal ring stuck on phone either. I have mine mounted right below the drivers temp up-down and it holds my 12 mini perfectly.
#129
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I doubt that'll hold the 12 Pro Max's weight...
#130
DBLex1 (07-09-21)
#132
Center speaker grille + RAM track + RAM x-grip = easy and sturdy solution.
https://forum.ih8mud.com/threads/mr-.../post-13833075
#134
I purchased two Carmount brand magnetic mounts (with nano gel instead of tape) and placed them on the flat climate control surface above the cd slot.
It allows me to mount my iPhone on one without obstructing anything and I can use it and connect a charging cable if need be.
Or... the real reason I did this... I can magnetically mount my iPad mini 4 for road trips.
Do I want Carplay? Of course. But, with this setup, I don't need it.
tntcandy (10-04-21)
#135
Super Moderator
