Wind Noise
If the vehicle is equipped with ventilated front seats, disable them for the duration of your test drive and check back here. My GX is "tomb" quiet. It sounds your particular dealer will say anything to sell you a car. Test drive other brand new GXs to see if it exhibits the same symptoms you are experiencing.
I was really hoping it was something simple and it was the ventilated seats. Do the doors close properly? maybe check the rubber seal around the door on both sides of the vehicle so you have a reference point. Hope you get it sorted soon.
Wait...I had similar problems and dealer easily fixed it.
I'm on mobile and it's hard to use the search function but please search using my login name to see if the fix can be applied to you.
Good luck.
Went out and snapped a quick picture. The fix is that fell foam you see in the center of the pix.
Good luck.
i and the dealer both agreed that the wind noise is coming from the rear seat belt pillar. All windows and doors were completely closed. The dealer kept saying it is normal to GX, which I do not believe it is.
This Saturday I will test drive GXs on their lot to see if those GXs have the same noise inside coming from the rear seat belt.
Good luck.
Good luck.
Currently, my GX is with the dealer’s service center cuz I denied to pick it up as the issue has not been addressed properly. I am going to go to the dealer again and show them the pic you posted here.
thank you
I don't know what cause the wind coming through the seat belt pillar and making noise there.
I will point out to the dealer to check the rear wheel cover. perhaps it is not securely tightened so wind comes in through the gap?
I have very faint wind noise as well on my '18. Only noticeable with radio off. II have no idea where it is coming from but t is a wind noise since it only happens during high winds or at higher speeds. It almost sounds like an old school radio tuning or a crack on the window but very faint.
I read a thread about a sort of whining noise towards the rear of the cabin that occurred after a modest 4 wheeling adventure. It turned out that electrically deploying the third row seats and then re-stowing them stopped that noise. It does not sound like this is that, but it's an easy gambit. Best of luck with it.
Wind Noise
New member here....2016 gx460 has a wind noise whistle around 45mph and up. Put sunroof up for vent seems to stop. Thought it was the roof racks although I cannot figure out how to remove. they seem to gave key locks on each side?? Tried valet key does not seem to work? Any ideas?? Planning to take to dealer for inspection as this is annoying.
Welcome to CL
You have OEM cross bars? Not sure why venting the sunroof would resolve this.
https://www.clublexus.com/forums/gx-...tructions.html
Before I installed my full length overland rack, I did not have any noise when my sunroof was open.
Now to clarify, not having any noise with an open sunroof is an ambiguous term. It will never be as quiet as if it were closed, so that being said, are you maybe being too sensitive about the wind noise?
Suggestions:
Suggestions:
- If you have the cross bars, another option may be to move the cross bars further forward or back depending up their relationship to your sunroof. If a cross bar is just over your sunroof I can see there being an unacceptable amount of noise.
- See if you can purchase or make a wind screen to go in front of your sunroof.
2017 GX 460 Wind noise & dash lights
Purchased a L/Certified 2017 GX 460 Premium 13 months ago. More than long enough to have two complaints: (1) Excessive wind noise, always. I keep looking back to see if tailgate window is open. Noise is shocking to me. Was not expecting this of Lexus. Especially, since Consumer Reports' review of the 2017 states "The cabin is outstandingly quiet, with barely any wind or road noise, and just a pleasing hum from the engine." This in NO WAY describes my GX. Pulled along side another GX recently & asked the driver if she has a lot of wind noise. She immediately replied "YES." All rubber seals on all doors/windows are fine. Anyone else experience the wind noise?
(2) Don't understand why manufacturers insist on having sensors to auto dim/brighten dash lights. I want to set mine & have it never change. Been through all the driver accessible settings & "dealer only" settings. Can't seem to change this. Dealer says only way to "disable" the feature is to set dash lights to full brightness. I don't want that. Drive under an overpass, dash lights dim or brighten. Annoying to me. Often, less is more. Stop controlling everything! I want to control my own s&%t!!! Anyone else?
