Rotors
Old 07-31-19, 04:12 PM
  #121
Acrad
Super Moderator
Acrad's Avatar
Received 3,657 Likes on 2,394 Posts
Originally Posted by John00
Centric rotors with E-Coating
Havent had them rust yet
althought the rust isnt a big deal, it can cause things to stick together and doesnt look nice
No issues with the stock ones so far but will try these out next time. I did a pad slap on mine last year.
I've had good luck with Centric in other applications
Rear rotor backing off parking brakes for removal
Old 08-02-19, 05:19 PM
  #122
TexasAg
TexasAg's Avatar
I have a set of TRD pads never installed from my 5th gen 4runner, do you think i can use them on my 2014 GX460?
Old 08-04-19, 08:02 AM
  #123
John00
John00's Avatar
look up the part numbers for both vehicles. if they match you should be ok to use them.
Old 08-06-19, 11:10 AM
  #124
Chow
Chow's Avatar
Can you point me to what specific ones I should get? Not a mechanic, but saw a youtube video and this does not look too difficult to do to save some money.
Something like this: https://www.carid.com/centric/prefer...brake-kit.html
Old 08-06-19, 01:29 PM
  #125
bbqsoup
bbqsoup's Avatar
The Akebono I used is ACT976 for Front and ACT606 for rear
You can go to Rockauto.com and see all the part numbers
https://www.rockauto.com/en/catalog/...brake+pad,1684
Old 08-06-19, 03:21 PM
  #126
John00
John00's Avatar
Originally Posted by DallasDave
We recently had a brake job done at NTB. The GX was in for a balance/rotation and they alerted me to the front brakes. I normally do these jobs myself, but we were leaving for a long trip (taking the GX) so I let them do it. It was ~$450 for front pads and new rotors. The rear brakes were fine.
To me, your Dealer quote seem VERY high since they are not replacing the rotors.
BTW, the NTB rotors now have rust on the rotor "hats" and looks like crap. The wife doesn't notice it (it is her ride) but I will be replacing the rotors myself in the not-too-distant future. I am not knocking NTB, just a reminder that there are differences in the quality of work and the parts used.
late yeah but ill still add a comment.
maybe on some areas one of those rust restorers/converters, the kind that turn black would be good enough. loctite makes a good one.
would have to be careful not to get on the actual braking surface
its an acid that converts the rust into a protective coating.
Old 08-12-19, 05:10 PM
  #127
TexasAg
TexasAg's Avatar
FYI, I checked part numbers for stock pads on both the '14 GX and the '12 4R and they are the same part number so TRD pads for the win!
John00 (08-12-19)
Old 08-12-19, 08:51 PM
  #128
GoHuskers
GoHuskers's Avatar
I'm interested to know the differences between the normal vs TRD pads.
Also, you have the part numbers? Thanks.
Old 08-13-19, 07:17 AM
  #129
Swiftyfit
Swiftyfit's Avatar
Local dealer here wanted $650 for pads and resurface on our IS350. Haven't had them quote on the GX yet but its much cheaper to DIY or bring your OE parts to a trusted mechanic.
Old 09-21-19, 04:42 AM
  #130
Acrad
Super Moderator
Acrad's Avatar
CEIKA CUSTOM BIG BRAKE KIT FOR LEXUS GX460 (URJ150) (10~15)
Old 09-21-19, 08:29 AM
  #131
cb1111
cb1111's Avatar
Do you have any experience with these?
Old 09-21-19, 08:30 AM
  #132
Acrad
Super Moderator
Acrad's Avatar
No. Just came across them in searches.
Old 09-21-19, 10:43 AM
  #133
cb1111
cb1111's Avatar
From my (albeit limited) experience with BBK, I'd opine that most don't bring any advantage in day to day driving, but will add noise. I'd suggest getting a different set of pads and go from there. The slotted/drilled rotors bring no benefit unless you on the track.
WRD4chano (01-27-20)
Old 09-22-19, 01:26 PM
  #134
tecman
tecman's Avatar
But the roads are MY track
Old 09-22-19, 01:33 PM
  #135
cb1111
cb1111's Avatar
So true....
Quick Reply: Rotors
