Factory Alarm
Old 09-03-21, 02:06 PM
  #61
Acrad
Super Moderator
Acrad's Avatar
Received 3,637 Likes on 2,383 Posts
I wish there were logs related to cause of alarms but I haven't seen them. There could be something in there on the '19+ Enform systems though that isn't readily published. Bring up to dealer and at least rule that out.
'16+ Enform in general has far more integration with vehicle than previous years. Not saying related but just brainstorming.
You can't rule out some kind of 3rd party interference as well. Do you have any nearby military bases?
Old 09-03-21, 02:32 PM
  #62
Toofless
Toofless's Avatar
No military bases close by that I know of. It started occurring August 18 and seems to be picking up in daily frequency at same time frames.
Just pulled the dealer window sticker and it does have the GBS sensor equipped.
Old 09-03-21, 02:35 PM
  #63
Acrad
Super Moderator
Acrad's Avatar
You might try unplugging the microphone as a test. That cover drops easily and the microphone disconnects as well.
Old 09-03-21, 03:32 PM
  #64
Toofless
Toofless's Avatar
I'll give it a shot.
Until then, I'm going to disconnect the battery at night until my appointment on Tuesday with the dealership. I need my sleep. Any issues with doing this I should be concerned about?
Old 09-04-21, 04:41 AM
  #65
Acrad
Super Moderator
Acrad's Avatar
Ironically had mine went off this morning for no apparent reason.
Old 09-04-21, 04:58 AM
  #66
Toofless
Toofless's Avatar
Ironically had mine go off this morning for no apparent reason.
Just turned my alarm off right now lol. I wanted to see if the pattern continued...
One thing I've noticed lately is after starting and reversing out of my driveway, when I shift to drive and accelerate, there's a noise that comes from somewhere below the steering wheel. It sounds like the shutter of a camera when taking a picture. Maybe some sort of solenoid? Started hearing it around the same time that the alarm issue began.
Old 09-04-21, 05:15 AM
  #67
Acrad
Super Moderator
Acrad's Avatar
I notice starting with the '20 model year they added some additional logging that your dealer could query with Techstream to see what component of the system is triggering the alarm.
Old 09-04-21, 05:19 AM
  #68
Toofless
Toofless's Avatar
Ahhh try and match it up with the logged times. Nice. I'll mention this when I'm there.
Old 09-04-21, 06:00 AM
  #69
Toofless
Toofless's Avatar
I just had to disconnect the battery. 4:45am, 5:23am, and now 5:50am. This is effing ridiculous. Hope the techstream data is still stored.
Old 09-04-21, 06:20 AM
  #70
Acrad
Super Moderator
Acrad's Avatar
Might be a defective door jam or hood switch as well. The hood microswitch is commonly reported with alarm errors when I look around. Marginal continuity influenced by humidity or temps raises to a level that car thinks it is an electrical open and then sets the alarm off.
Toofless (09-04-21)
Old 09-04-21, 09:02 AM
  #71
Toofless
Toofless's Avatar
Okay. Could it be possible that this dude is taking a ride with me to work, waiting 9 hours, and coming home with me? Or did this dude possibly chew a wire?
Acrad (09-04-21)
Old 09-04-21, 09:16 AM
  #72
bbqsoup
bbqsoup's Avatar
My alarm has been going off a few times the last couple of weeks too. No pattern. However it seems to be shorter duration than the last time it went off.
Old 09-04-21, 10:12 AM
  #73
Acrad
Super Moderator
Acrad's Avatar
That critter in the engine bay isn't helping. :-)
That data logging is actually available even in old Techsteam installs and I see on my rig.
My alarm said it was the Glass Break Sensor. I guess I need to turn down the sensitivity. I unplugged microphone for now since I am in a spot it might happen again.
Other interesting logs are Windows and General Locking.
My VM time is off several hours... timestamps are based on PC clock.
Old 09-04-21, 10:42 AM
  #74
bbqsoup
bbqsoup's Avatar
Also checked your remote batteries too. I remembered the last time I had this happened I replaced the batteries and that went away for a long while. Now it’s back but not as frequent but I’m going to check the batteries too.
Acrad (09-04-21)
Old 09-04-21, 10:47 AM
  #75
Acrad
Super Moderator
Acrad's Avatar
In my old 12.x version of TS the logs I posted above are at:
System Select -> Main Body -> Select UTILITY -> Operation History
It is self explanatory after that
Quick Reply: Factory Alarm
