Factory Alarm
Old 08-06-23, 08:09 AM
  #91
BCritter
10th Gear
BCritter's Avatar
Default 2012 GX460 Alarm randomly goes off
I have a 2012 GX460 and my alarm keeps randomly going off if the vehicle is locked. I'm currently on a trip so I've not been able to hook up tech stream and see if there are any codes, but there's no info on the multifunction display or lights on on the dash. I tried removing all the door sensors (the part that tells the car if the door is open) and the problem still occurs. After I lock the car sometimes the alarm goes off in 15 minutes and other times it can be a few hours but it's ALWAYS goes off if it's locked. Has anyone else experienced this issue or have any ideas on how to troubleshoot? The only way to keep it from going off has been to leave the doors unlocked- which is fine while visiting my parents in the middle of no where but that's not gonna work long term. Any guidance welcome!
Old 08-06-23, 11:40 AM
  #92
Acrad
Super Moderator
Acrad's Avatar
Received 3,637 Likes on 2,383 Posts
Do you have the Glass Break Sensor?
https://www.clublexus.com/forums/gx-...l#post10428032
It has adjustable sensitivity and is plug and play. As a troubleshooting tool if you don't have access to TS you could unplug the ECU (if equipped).. it is in the area where the MTS ECU is located
Techstream has an area you can look at what triggered the factory alarm
https://www.clublexus.com/forums/gx-...l#post11119729
Old 08-29-23, 03:56 PM
  #93
gfcipriani
gfcipriani's Avatar
Does anyone know if the GBS PT39860111 works with late model 2022-2023 GX460s? One parts website LexusPartsNow claims compatibility, however OEMVehicleParts says it is not. Anyone with a late model GX perform this GBS install and able to report results? TIA
Old 08-31-23, 08:41 AM
  #94
gfcipriani
gfcipriani's Avatar
Bumping this old thread to see if anyone knows if the Glass Break Sensor module is compatible with the 2022 GX460... TIA
Old 08-31-23, 08:48 AM
  #95
Acrad
Super Moderator
Acrad's Avatar
Lexus parts sites shows as compatible
https://parts.lexus.com/p/69524568/PT39860111.html
IMO: I would disregard any discrepancy on trim and year
Old 09-03-23, 03:24 PM
  #96
John00
John00's Avatar
a note on the glass sensor. if you leave a water bottle (plastic) inside and have the cap tight, the bottle will expand as the interior heats up. it makes a crack sound as this happens and sets off the alarm. need to leave the cap off.
BananaGS
12-17-01 07:27 AM
RaptorsFan
Maintenance
08-06-01 10:13 PM
Quick Reply: Factory Alarm
