Lexus Air suspension lock?
Hi guys
I have problem with the Air suspension,
as you know after about 55km its automaticly go to normal mode
is it possible to lock the rear suspension on HIGH mode only?
Someone told me i can remove the system fuse and that gonna work
but idk wheres the fuse located
thanks
thanks
Hi guys
thanks
thanks
High Settings revert to Normal Height above about 18MPH. It's the same way on GX 470 as well. Low reverts at 7MPH.
OP: You'd probably have better luck adjusting the rear sensors than pulling fuses or you will likely get dash error messages. Fuses/Relays are in the fuse/relay block in front of the brake master cylinder.
Acrad (12-08-18)
Ceriel
20
11-05-16 07:13 PM
pepe88
GX - 1st Gen (2003-2009)
17
01-02-12 10:30 PM
