Protective Paint Film Questions, Comments, Concerns
#31
I didn't expect the clear bra to take the impact, just saying that I was pissed about having to fix the bumper and put a new clear bra on. I didn't go through insurance because I had a freebee since I was accident free for so long and didn't want to use it up on this since it wasn't too much to fix. Good thing too because I just used my freebee up recently and it was my fault (luckily no damage to my car) so my insurance will not go up because of it.
#33
My vehicles have NEVER been through a car wash! ALL car washes will scratch your vehicle. Actually, no matter how you wash your vehicle, you are scratching the finish but auto car washes are the worst. I would think a car wash would wear/damage the bra (over time), especially around the edges.
Koz
Koz
#34
#35
I don't do automatic car washes except when it is at the dealer and haven't had a problem in the 10+ years I have had clear bras.
One thing to consider when looking at clear bras is the type of clear bra you want. I happened to call my clear bra installer yesterday who I have worked with since I started using clear bras about adding some things and we had a conversation on the different films out there. Not all are created equal.
Ventureshield - Easy to install, no clearcoat and therefore no orangepeel look so you can't tell it is there but is does not protect against the elements as well.
3M scotchguard - Harder to install, has clearcoat on the film and has an orangepeel look but protects better against the elements.
Expel - Has the benefits of both above, no orangepeel and has clearcoat that is self healing which is supposed to work great. However it is harder to install so that adds to the cost.
My installer uses all three depending on the customers wants and says the Expel is a game changer in the industry although the longevity questions are unanswered since it is newer than the other two.
Do a search on these and make a decision for yourself which you would prefer.
#36
#37
Ventureshield does have a urethane clear-coat and is not easy to work with because it is thick (8mil). It's so good 3M had to eliminate the competition by buying ventureshield!
BTW - The higher the vehicle the less ding/chips.
Koz
Koz
#40
2014 GX 460 3M bra?
Has anyone gotten the 3M bra for their GX 460? I didn't get at the $tealer as they where asking 1K, and I thought that was too expensive for something I had not done adequate research on yet.
I have a couple of questions:
1) Is the 3M bra worth it to get? or is it gimmick?
2) If it is valuable, what areas should be covered?
3) what is the good price to have stuff installed?
thanks!
thanks!
#42
#43
Absolutely get one! I did not on my previous car and I regret it as I watch front end getting damage from road debris and bugs and what not. Eventually I end up doing it to stop further damage from occuring anyways.
I got my GX clear bra before I took delivery and drove it home for that reason. After a year the front is spotless. Also it doesn't make you cringe as much when you are behind some big truck on a highway and stuff flyin off of it right into the front of your car. So for me it also adds some piece of mind. The prices will differ on whether it's a pre cut or custom kit. Definitely get the whole front covered including the bumper.
#45
I'll never drive another new vehicle off the lot without it again.
