2014 Lexus GX460 Stuck on loading Screen
Hello,
I have a 2014 Lexus GX460 base model. I do not have a navigation system on this certain model. Recently, I have encountered an issue that I thought would eventually go away but has not.
My vehicle's screen which has the climate control, audio, weather, etc controls is stuck on a loading screen which I have never seen before. I have tried doing a reboot by holding down the volume button, but it just returns to me loading screen which is in an endless cycle. I have tried researching as much as possible to see if any other owners have encountered a similar issue, and I have only seen one other thread on this site where an owner with the exact same year, model (base GX460) has had the exact same issue. I am completely lost as to what to do.
Additionally, I brought it out to my local Lexus dealership and they attempted to reset it or something, but that did not work. They told me they have never seen this issue before which is extremely worrying to me. They told me they pretty much have no idea what to do to fix it and they proposed replacing the whole screen system for approximately $2000. This is an extremely frustrating issue as this screen is responsible for many functions of the vehicle, and I honestly would not like to spend the $2000 if I can avoid it as it does not even seem to be an issue with the screen. Furthermore, the back up camera actually shows up on the screen. I am confused, because I figured if the screen was broken then the back up camera function would not work either, but this still does. Have any other owners experienced a similar issue and been able to resolve it?
Thanks!
Thanks!
Super Moderator
Unfortunately, you may have a "rare" and defective infotainment unit. I believe camera switching can occur at a higher level outside of the rest of the infotainment unit operation.
Have you disconnected the vehicle batter for at least 10 minutes?
I assume these diagnostics are also unavailable to access.
https://www.clublexus.com/forums/gx-...agnostics.html
Hello,
Thanks!
Thanks!
Acrad (12-27-18)
Super Moderator
Looks like the lower part new is around $1500 for a base model.
