Transmission Failure or Issues
#138
It doesnt happen all the time, just catches me off guard during stop and go traffic or im just going slow because of snow. Feels like the transmissions would just downshift a few gears thinking I need the extra power. It happens even after OT. High speeds it shifts fine.
It's normal. The transmission downshifts if you tap the brake pedal, normally on a slope but I've noticed it on a flat surface as well.
#140
Yes, while coasting and tapping the brakes it may down shift on flat surface. It happens almost all the time coasting on downhill but it happened on flat or slightly downhill surface for me too.
#141
I have experienced some clumsy shifting at low speeds. Exactly what you describe - it feels like it downshifts thinking it needs more power when I really just want a smooth power delivery. I am never in much of a rush in my GX, I just want a smooth ride, so it can be frustrating at times. I just try to be very smooth and light on the throttle. At times it can be very rough between 5-10 mph... Not very lexus like...
#142
#143
I understand that, and I can live with it. My last truck was a 4x4 suburban and I never experienced any clumsy behavior from that truck. I think some of the transmission hunting around comes down to programming of the 6speed. Its clear that the computer wants the transmission to get to the highest gear possible in the interest of fuel economy.
#144
#145
I have a little bit yes, I find the manual shifting very clumsy (I know, I keep using that word) and slow to react to my inputs. I didn't buy the GX to row my own I have an old 911 for that. Maybe I am just used to making my own shift points when driving my old 911. I have learned to live with the transmission on the Lexus. Perhaps it also has to do with the relative lack of low end torque from the 4.6 vs a bigger v8 like the 5.3 in my old sub or 5.7 in the LX?
#146
Maybe you just need to take your 911 for a spin? I used to own a 94 300ZX Twin Turbo and miss it badly.
#147
Super Moderator
I gotta tell you ... not sure how but Pedal Commander smoothed out low speed maneuvering on mine. Parking lots were a little odd previously but on ECO mode it is very smooth. I know many won't believe it but it really does change the drive-ability of vehicle and smooths out the very few rough edges.
#148
#149
I started to use ECO quite alot during slow commute...it really smooth out the acceleration and deceleration. I barely experience jerkiness with sudden downshift or upshift.
#150
Super Moderator
It may take a couple more runs over the pass but I think I might have gained another 1-1.5 MPG with ECO -4. I do play with the performance modes but on the long haul runs turn it down for mileage. Pedal Commander is sure to be like bringing up politics or religion in forums for the foreseeable future. I'm sold and considering for other vehicles as well. It did things I didn't think were possible just from a differently throttle mapping. If someone complains about an overly aggressive cruise control.... PC will fix that. I think it does the throttle by wire trick where a mash doesn't really open but a partial followed by foot down opens throttle plate fully wide. I think it somehow allows for fully foot down to act like cable throttle and open fully wide.
IMO: Everyone seems to think it is the "mash throttle" mod and it is so much more than that. Frankly...I'm not really even using it in that mode much....said it before... try it out and send it back in if not satisfied. You will be out return shipping.
I think one who even does slow technical off-road would appreciate what it can do in the less sensitive settings. Second Start mode and MTS actually do some of things that PC does as well in regards to throttle.
bbqsoup (01-08-19)
