Transmission Failure or Issues
#361
#362
+1 and even if you manage to grab it you're going to be challenged with threading it back through the fill hole. Looking at other responses you may have to go the route of removing the axel to have the best chances of taking it out. I had a similar issue to this while changing my differential fluid and ultimately was able to fish it out with some pick and hook tools. Unfortunately, I don't think you have the room to maneuver with those tools? Although, the grab tool you showed in one photo may work if you can thread it threw the cap and then open it on the opposite end. That should allow you to eventually line it up with the fill hole on removal but man it's going to be like the game of Operation.
Rest assured. I’m not giving up! However, we are traveling to the beach for a long weekend for a “baby moon” so to speak. I’ll catch back up on Monday when I get back to a stack of boxes at my door and get back to work.
nuclearn8 (02-11-21)
#363
If you had a medical endoscope and endoscopic graspers, it would be an easy job. Those scopes are steerable in x & y. So they can be aimed by twisting some ***** as one advances the scope. The the grasper feeds through a lumen down the scope. A handle on the outer end of the grasper lets the operator open and close the claws. The scope's x / y controls are used to aim the scope and grasper together. That's how they can grab polyps a few feet inside a body even after making a few 90 degree turns.
Reasonable price automotive inspection flex scopes are simply frustrating for tasks like this, because you can't independently steer their ends after they pass into the machinery.
Given the inability to manipulate the scope tip shape after entry, but only having a preform shape, I'm with the idea of advancing a long spring wire alongside the scope with a hooked bend on the wire to engage the nipple. My goal would be to pass the small hook through the nipple and use the wire to drag the nipple up to the hole. Once in range, grab with a more stout, long 90 degree plier or offset pickups to pull it out.
#364
consumer grade precision colonoscopy scopes as you describe but that is exactly what’s needed.
I have some 90deg alligator forcepts that were perfect but just out of reach. (I have a ton of random
*** tools). I have a few different lengths on order. I can certainly reorient the nipple
with a wire attached to the lens. Then it’s just putting it in a known spot in grasp of my best tools. I’ll use the forceps to bring it to the hole where I can insert a wire hook or hook tool to pull it through from the back of the object. That’s my mental plan at least haha.
#365
A long, curved "fishing" hemostat might be a good option. They are can be had in 10 inch lengths and occupy little space in a bore, but they do need a bit of expansion space to open/close.
I have a pair of alligator forceps for retrieving wires that are just out of reach. Takes up very little bore space and the shaft does not expand when you open close. Got mine from an electronics equipment shop, unfortunately, now long closed. The offset handle also means easier to see and grab at same time through a small hole. Unfortunately, they are straight, and cannot be curved due to the way they work.
Look on Amazon for "alligator forceps" and you can get them to 11 inches reach.
They are very handy and grab pretty dang firmly. The ones on Amazon are reasonable priced and you can get in different reach lengths.
(EDIT: oh wait you have a pair. I know them as endoscopic forceps and didn't realize we were talking about similar things. Only until after running into alligator in a search did I edit my note to call them alligators. Then I realize you have a pair and have more on order!)
#366
Yep! Those things are awesome- just hoping the length I need will fit into the hole. Even though I attempted it with a shorter pair, I had kinda forgotten about getting a longer pair until your message. Fingers crossed.
#367
Difficulty shifting into park.
I’ve had the new to me 2017 GX with 30k miles for a few weeks and yesterday I drove it for my first long drive 250 miles. After a few normal stops, when I got back home it took a few tries before I could get it into park. Reverse,Neutral and drive was fine and after a few shifts going back and forth it went into park. Has anyone else experienced this?
#368
Super Moderator
Here are some pics of the transmission cable control cable assembly. I wonder if it is sticky or binding?
Post 267
https://www.clublexus.com/forums/gx-...l#post10914080
Post 267
#370
The following 2 users liked this post by Seattle SCone:
HanksLexus (02-14-21),
kode3 (02-14-21)
#372
Unfortunately it has been brought to my attention that Hank did not make it home... It was determined that a mechanic working on the plane accidently dropped a small piece of plastic into the injectors causing a horrific crash.
The following 18 users liked this post by HanksLexus:
Acrad (02-16-21),
dtaski (02-18-21),
dwh13 (02-16-21),
eburggx470 (02-16-21),
hzhao (02-17-21),
and 13 others liked this post.
HanksLexus (02-16-21),
william489 (02-16-21)
The following 3 users liked this post by nuclearn8:
