Transmission Failure or Issues
Old 07-16-21, 07:33 PM
  #436
WRD4chano
WRD4chano's Avatar
Originally Posted by whodat000
Is the manual these directions come from available? If so, where/how? I have code P0705 [Transmission Range Sensor Circuit (PRNDL)], but in addition the shifter lever doesn't feel right, like there is some hangup with the cable or linkage.
here yah go
Old 07-19-21, 10:04 AM
  #437
whodat000
6th Gear
whodat000's Avatar
Default Tech Doc
Thanks for the reply...
I had seen that link in the past, but couldn't get it to work - still can't. When I follow the link it takes me to a Google Docs page, and I get an error message. [pic below] It does offer the option to download the file, which I did, but when I extract the zip file, it does not appear to be usable. Any guidance on what I need to do to get the downloaded files to work?
Old 07-19-21, 10:11 AM
  #438
whodat000
6th Gear
whodat000's Avatar
with picture:
Old 07-19-21, 07:01 PM
  #439
WRD4chano
WRD4chano's Avatar
with picture:
sorry about that, i was in the same boat when i first downloaded it.
open the folder
open the rm14k1e folder
then double click the index2.html
it'll then open in your browser. (i use edge, for some reason it doesnt seem to work on my firefox)
Old 07-20-21, 05:43 PM
  #440
Havabrain
Havabrain's Avatar
Default Experiencing same in 2002 ls430. Even in reverse.
Originally Posted by CaptMarty
Is anyone experiencing a low speed transmission surge or hesitation when appling first applying the gas at parking lot speeds.? I especially notice it when traveling downhill or a slight decline. The motor revs as if in neutral then the transmission catchs on. I mentioned it to the dealer at the 1000 mile check up and they said they could not find anything wrong. I'm getting ready to take it in for the 5000 mile service. Any help would be greatly appreciated. Not a very smooth transmission considering the price.
Thanks
Tampa FL
Experiencing same thing...notice it mainly after first start up. Pulling out of parking space will go to neutral while backing up. Then at stop sign it hesitates then jerks Into gear... Had car for a month and only noticed this after oil change.. I know unrelated but had to say it's only thing that had been done before problem.. car has 148k miles. Any thoughts would be helpful
Old 07-21-21, 10:33 AM
  #441
whodat000
6th Gear
whodat000's Avatar
OK - great! It is good to know to go to the index2 file, and especially good to know it seems to not work with Firefox - which I was using by default. When I told it to open with Chrome, it appears to be fine. I will now see if I can troubleshoot this thing. I started with an error code for the 'transmission range sensor A circuit' [code P0705], but since I also could feel the shifter didn't feel right I figured the sensor might just be telling the truth and the shifter was not cleanly in a single expected position. I opened up the center console and lubricated the ratchet assembly, cable end and the bushing. Then reset the code, and have had little problem with it since. BUT, I think my fix is temporary and I want to be prepared for the eventual further work. I suspect it will be either just the bushing, or maybe the whole cable assembly. If anyone has thoughts on this, I'm all ears!
Thanks again on the manual guidance.
Old 08-07-21, 12:23 PM
  #442
Acrad
Super Moderator
Senior Moderator
Acrad's Avatar
Received 3,676 Likes on 2,404 Posts
I uploaded this one long ago in the TSB thread but something for 2010 owners to consider if you see these symptoms. There is an updated flash.
L-SB-0122-10Introduction
Some vehicles may exhibit the following shifting conditions:
  • Harsh shift on acceleration below 20 mph during the 2-1 downshift.
  • Excessive lock-up operation at freeway speeds about 50 – 60 mph, sometimes referred to as “busy shifting”.
    The Engine Control Module/ECM (SAE term: Powertrain Control Module/PCM) calibration has been revised. Use the following repair procedure to address these conditions.
Old 08-13-21, 04:10 PM
  #443
stevenatx
10th Gear
stevenatx's Avatar
Default 911 transmission?
911
Towing my RV from SC to CA. 2011 gx. 261k miles. Felt a shudder on freeway that felt weird. Pulled over on next exit near Chunk MS. Couldn't find any codes with torque lite connected to OBD2. When to go put car in gear and transmission made nasty noise. Immediately put it back in park.
Have been sticking to about 62 mph. Trailer should be well under tow weight. Any suggestions?
Transmission won't go back in gear now.
Jacket (08-15-21)
Old 08-13-21, 05:13 PM
  #444
Acrad
Super Moderator
Senior Moderator
Acrad's Avatar
No idea on fix.
Do you have something like AAA w/RV tier for trailer towing as well to get you to next town?
How is cell coverage? If ok...get OBD Fusion and purchase the Toyota/Lexus expansion pack so you can get at the codes.
https://www.clublexus.com/forums/gx-...and-gx460.html
Old 08-13-21, 06:53 PM
  #445
tecman
tecman's Avatar
Ugh, sorry to hear this. please keep us posted. The GX transmission is pretty reliable so curious what the outcome is.
Old 09-27-21, 04:24 PM
  #446
Voogru
Voogru's Avatar
Default Transmission blown at 60,000 miles?
Hi,
I recently had my 2017 GX serviced at a Lexus dealer, prior to the service the transmission was shifting fine. I had a drain and fill performed in line with the manuals recommendation. The GX has been serviced only at Lexus dealerships since I've owned it (almost 2 years). Immediately after the service, the transmission developed a shudder between 30 and 40 MPH with the engine RPM around 1200-1500 RPM, with an occasional more violent shudder on light acceleration around 20 MPH.
I brought it back to the dealer immediately, and they're now saying that the transmission needs to be replaced.
Has anyone heard of this with the GX? I've been driving Lexus/Toyota vehicles for over ten years, and never had a transmission fail immediately after a fluid change, or ever fail ever at all with multiple vehicles with over 200,000 miles over the past 15 years.
Old 09-27-21, 04:27 PM
  #447
ASE
ASE's Avatar
Received 1,071 Likes on 714 Posts
What service did you have performed ... just the fluid change ?
Old 09-27-21, 04:28 PM
  #448
Voogru
Voogru's Avatar
Drain and fill, oil change, and tire rotation.
Old 09-27-21, 05:13 PM
  #449
Acrad
Super Moderator
Senior Moderator
Acrad's Avatar
I wonder if they didn’t do a proper fluid level check? Basically…under or overfill condition
Old 09-27-21, 05:25 PM
  #450
zippymbr
zippymbr's Avatar
That is BS if they changed the fluid and then it failed they are responsible. IF they do not take responsibility call Lexus right away. Lexus dealers value customer relations score it determines allocation amounts and many other things, they want to keep you happy. After a fluid change there can be an air bubble that will cause a shudder. I bet the fluid is low not high. If they followed the fluid change procedure. https://www.clublexus.com/forums/att...sion-fluid.pdf
jphowey (09-27-21)
Quick Reply: Transmission Failure or Issues
