Install light bar, how to tap into fuse box?
I am installing an aftermarket light bar to the car. The light is connected to battery while its remote control receiver needs tap into engine bay fuse box. The best choice would be a fuse that comes on/off with ignition so the receiver doesn't consume power when the car is off. I went through almost all nonessential fuses with multimeter and they all remain hot after ignition is off. When I tried rear window deicer and defogger but they are off even after engine start. Did I do something wrong? Any suggestion on the fuse slot?
I used WIP RR for my dash cam.
https://www.clublexus.com/forums/gx-...ox-wiring.html
My dash cam shuts down when I turn the car off and I am still in the car.
Yes. courtesy lights were off and I locked the car just to be sure.
Same here with my dash cam. But it was wired to the cabin fuse box next to parking brake pedal.
Please make sure to use a fuse tap to be safe, comes with inline fuse:
https://www.walmart.com/ip/Cooper-Bussmann-ATM-Add-A-Circuit/52034992?wmlspartner=wlpa&selectedSellerId=0&wl13=789&adid=22222222227000000000&wl0=&wl1=g&wl2=c&wl3=42423897272&wl4=aud-566049426705la-51320962143&wl5=9026901&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=local&wl12=52034992&wl13=789&veh=sem&gclid=EAIaIQobChMIu6bKkpn23wIVTksNCh0t_QnTEAQYAyABEgJ0pvD_BwE
psun786 (01-17-19)
Although what's above will work, one that more resembles the fuse should be used. This gives more assured seating.
There's a lot of confusion on names and types of fuse styles.
tnilc
RC - 1st Gen (2015-present)
07-04-18 07:15 PM
RSpi
08-25-17 05:51 AM
vanrealty
03-11-12 08:15 PM
