Tow hitch feedback
I took the time to look at both your Amazon links and my conclusion is that:
I would truly be more concerned about their quality and reliability if I were pushing the upper tow limits of your GX.
- they both look identical
- they both have great reviews/ratings
- the material thickness looks the same on both
If you're not getting a fullsize hitch and towing a boat or trailer, then get a cheap one from eBay. It can tow up to 5000lbs and it is almost the same if not the same as both listed above for much cheaper. I got one and the quality is very good. I only use it for bike rack, cargo trays etc...
For newer GX, you may need to push a few washers between the bolts to clear the bumper.
https://www.ebay.com/itm/Trailer-Tow...S!-1:rk:9:pf:0
Thanks fellas.
It will mostly be used for a bike rack, or tow a small camping trailer (under 3500 lbs loaded)
The Ebay item is only for US buyers. I'm in Canada. No such thing on Ebay Canada.
Heck, if you went and spent all that money on a Lexus GX 460, what's another $150ca to you for a simple hitch?
Tip, make sure you use either stainless steel or hardened nuts and bolts. DO NOT use any old steel nuts and bolts.
Also, I always use nylon insert nuts (sometimes called aircraft nuts). They will never come loose.
Just put the Lexus full-on hitch on a 2019 GX460 ... $345 and 90 minutes later, I now have a real hitch versus just a receiver. Comes in a Toyota box.
Stainless Steel fasteners is a no-no for any load applications (suspension, hitches, steering..etc) since SS can shear easily. Grade 8 bolts and nuts are recommended.
Or, as mentioned, just use whatever fasteners that came with the hitch, it will be rated for the load it can withstand.
Thats the one I have. Came with the cover also. My main use is protection from others in parking lots. I have no reason to think that it couldn't handle most loads.
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1124/15490355041161342001214_e75eccf1d76f1bc67a194a488a7e45d1e1d4d1b4.jpg)
Considering one of those hitches for my 2014 GX. For any members who has them, I appreciate if you can share your experience.
Drawtite 75685:
https://www.amazon.ca/dp/B004R37X24/...I3CGME0SX1VC4F
Curt 13043:
https://www.amazon.ca/dp/B003ZS32CW/...I14I92832B3K6I
Thanks!
Drawtite 75685:
Curt 13043:
Thanks!
cancruiser (02-01-19)
When you said lower the spare tire, do you mean lower it during installation, or lower it permanently to accommodate the hitch?
I also read some posts about the hitch fouling with the rear bumper in recent model years (mine is a 2014). Did you come across this issue?
Thanks again
Thanks.. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Thanks again
Thanks again
My bad for recommending SS bolts. Ya'll are right, absolutely agree, grade 8 bolts, but I'd still use the nylon insert nuts.
My suggestion was if the receiver didn't come with any hardware.
Yeah you're right. I saw the same Drawtite hitch from www.ebay.ca at the same price and free shipping.
https://www.ebay.ca/itm/Trailer-Tow-Hitch-For-10-19-Lexus-GX460-All-Styles-2-Towing-Receiver-Class-3/231714927540?fits=Model%3AGX460%7CMake%3ALexus&hash=item35f34933b4:g:ilMAAOSwZZlbnJKN:rk:1
f:0&vxp=mtr
If you just do light weight tows and bike rack this hitch would do just fine.
