Prado 150 Roof Rack Side Rails on GX460?
I know some folks purchased OEM parts from Japan for $900+, but has anyone tried one of these cheap Chinese 150 side rail kits from eBay? I am looking for the ability to add crossbars other than OEM or Inno and figured these may work. What I can't tell from the pics and description was whether or not they had all the rubber pads and mounting hardware, but I guess if they were worthy of mounting, I could source those separately.
Couple of examples (no affiliation w/ the sellers):
https://www.ebay.com/itm/Black-Roof-...0cX2Chdl7ys%3D
https://www.ebay.com/itm/1SET-For-To...8meF:rk:1:pf:0
You can also search for fenza here, someone else installed it successfully.
5th Gen 4runner rails also semi work too. I think one member here installed them and reported one of the back screw isn’t line up but they work. As with the GX470 rails, you need to find a way to patch up the holes for the middle feet.
If you don’t use the roof box 24/7 and only for trips, just get the Inno bars and put them
up when need.
up when need.
up when need.
up when need.
I love it so far...I did learn that the best fairing combo is in the 2nd position and using the noise reducing trim. Te only accessories I ordered were the awning brackets for my Batwing awning. It looks like I could have modified the Rhino brackets to work, but the Prinsu ones seemed well-made and were designed to work with the rack out of the box.
How did this turn out? I have searched this forum several times and I am trying to find the details on the capability of the 470 rails on a 460. Fenza no longer has the raised rails for the 460 on their site.
