Front Struts and Rear Shocks
Old 02-25-19, 12:25 PM
LFIL
LFIL's Avatar
Default Front Struts and Rear Shocks
We have a 2013 GX460 with about 91,000 miles on it. We took it to a local garage with a good reputation for an oil change and inspection. They called and said the front struts are leaking and worn out and the rear shocks are also worn out and the replacement will cost $1,175. They said the tires are cupping as a result. We've never had any struts or shocks replaced on any vehicle, although only one we've owned has had higher mileage than this. Also, the price sounds pretty steep. Any advice? Are we getting taken for a ride? We have to decide if we want them to order the parts and do the repair.
LFIL is offline
Old 02-25-19, 12:29 PM
tigmd99
tigmd99's Avatar
Does your GX have adaptive suspension or just regular?
tigmd99 is offline
Old 02-25-19, 01:16 PM
LFIL
LFIL's Avatar
By adaptive do you mean air suspension? If so, then no, just regular.
LFIL is offline
Old 02-25-19, 01:28 PM
rmason
rmason's Avatar
91k on the original struts aren't that bad and at least to me here in Los Angeles is very normal.
I've had the struts leak after 60k on my previous vehicle. DIY can be done with most regular tools with exception of spring compressors which can be borrowed and an impact driver.
Compressed springs are quite dangerous if not careful. The price given appears normal for all 4 replacements. imho.
good luck.
rmason is offline
LFIL (02-25-19)
Old 02-25-19, 01:58 PM
supperfly1
supperfly1's Avatar
I call bs. Get a second opinion. What are the chances are all done. You do heavy offroading?
supperfly1 is offline
LFIL (02-25-19)
Old 02-25-19, 02:56 PM
MCDavis
MCDavis's Avatar
Honestly, 90k and 5 years isn't outside of the realm of possibility for replacement, however I call BS on the price. I just added an assembled Dobinson's 2" lift and install for $1450 total, and that's a far upgrade over OEM components.
It's definitely worth a second opinion.
MCDavis is offline
LFIL (02-25-19)
Old 02-25-19, 03:24 PM
coolsaber
coolsaber's Avatar
A second opinion wont hurt. Anyone know of any good stock OEM replacements. RA and Amazon dont really seem to stock much KYB or trusted replacements?
coolsaber is offline
LFIL (02-25-19)
Old 02-25-19, 03:32 PM
Diablo6
Diablo6's Avatar
following....in a similar boat. Have 108k miles on the suspension of a used 2013 we just picked up. Thinking of doing Bilstein 5100s on all 4 corners for about $400. Not interested in a lift since it’s the wife’s DD.
Diablo6 is offline
Old 02-25-19, 03:38 PM
MCDavis
MCDavis's Avatar
You may want to look at the KYB offerings. Nothing against the 5100s, but they are a bit firmer than most stock setups, and valved more digressive than linear. She may enjoy the KYB.
MCDavis is offline
Old 02-25-19, 03:50 PM
tigmd99
tigmd99's Avatar
I don’t know...if you’re sticking with stock springs, then i would just stick to the OEM shocks IF you like the current ride/comfort of your GX. In my younger years, i tried aftermarket shocks on stock springs on various vehicles...never could match the ride quality of stock setup.
tigmd99 is offline
Old 02-25-19, 04:04 PM
BradTank
BradTank's Avatar
The entire reason shops have oil changes that they basically lose money on is to try an drum up business.
So just don't be surprised when you take your car to a place with an inexpensive oil change place and they say it needs expensive work.
I honestly doubt all 4 shocks/struts are blown and need replacement, but it's possible. Does the car ride poorly? Is it bouncy? Can you see any oil around the strut/shocks? Are the tires wearing funny (cupping)?
Even honest shops get their techs to upsale business.
BradTank is offline
LFIL (02-25-19)
Old 02-25-19, 04:23 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,637 Likes on 2,383 Posts
I know not under factory warranty but this is criteria Lexus uses
Acrad is offline
Old 02-25-19, 04:28 PM
LFIL
LFIL's Avatar
Ha, the only thing close to offroading is if my wife runs over the curb leaving a parking lot.
LFIL is offline
Old 02-25-19, 04:29 PM
Diablo6
Diablo6's Avatar
[QUOTE=MCDavis;10450852]You may want to look at the KYB offerings. Nothing against the 5100s, but they are a bit firmer than most stock setups, and valved more digressive than linear. She may enjoy the KYB.[/QUO
anyone have an idea on how the Ironman shocks might be for stock application?
https://www.metaltech4x4.com/ironman...rut-nitro-gas/
Diablo6 is offline
Old 02-25-19, 04:32 PM
LFIL
LFIL's Avatar
The oil change isn't necessarily cheap, and the place has a good reputation, but this does sound a bit fishy. To me, it rides fine. My wife, who drives it every day, has been complaining about a thumping noise and vibration in the steering when she stops. Brakes also inspected with no issues. They say the tires are cupping.
LFIL is offline
Quick Reply: Front Struts and Rear Shocks
