Recessed drawer door in surround front design to eliminate pry points.
Welded and multi-return flanged drawer and front for extra strength.
Carpeted top for cushioned work surface
Specs:
Constructed completely out of 16 ga cold-rolled steel.
Open Frame design to reduce weight
Welded and multi-return flanged drawer and surround front for extra strength.
Heavy duty full extension slides with cushioned positive in & out stops rated to support a load capacity up to 250 lbs in mobile applications constructed out of cold rolled steel in a zinc plated & clear chromate finish.
Steel riveted structural hat-channels for extra strength along top of drawer enclosure, slide mounting points and pull out drawer bin.
Inside drawer steel divider.
Free spinning hardened steel cover helps protect lock cylinder against drilling and pulling.
Security Lock with High Security Locking Cam.
1/4” (.250”) diameter D-rings on enclosure for multiple tie-down points.
i shoved the Milwaukee Packout system into mine. With the drawers I can go 2 wide and 2 deep with the back seat up. Since the packout is a modular system I can add and remove boxes as needed.
