Seat Ventilation / Cooler Questions & Comments
#61
Yeah, no true AC for ventilated unless something changed for 2022.
https://www.clublexus.com/forums/gx-...-comments.html
#62
After I posted this topic I did a search and found out the sad truth that the ventilated seats are inadequate. The 2008 RX 350 I traded in only had heated front seats so I am used to not having this option but when researching the GX options I thought the ventilated seats would be nice during the summer. Also I was under the impression that the ventilated seats would be AC air but now know it's just a fan moving ambient air and apparently very weakly. It would be nice for Lexus to correct this issue in their future automobiles.
rbyrd02 (04-26-22)
#63
MrTorgue (04-24-22)
#64
#65
I never use the ventilated seats feature ( even in TX heat ) .. feels, to me, kinda weird ( like my a$$ is wet lol )
#66
What I’ve found works best is to turn the rear ac on cold as possible and leave the front on auto ac and put the seat on coolest setting, your *** will get cold real quick (depending on fabric you’re wearing …. ) the ventilated seats work just fine imo
#67
I have a hunch (and this is purely a guess based on my experience) that the fan used in the 4Runner, which is pretty noisy when on high but works very well) was too loud for the Lexus brand so they found a different, more quiet fan, to use and it just does not operate as effectively as the one used in the 4Runner. Again this is just a hunch, but you can barely hear the fan on the Lexus GX and you can REALLY hear the fan on the 4Runner (when on High).
#68
Think my driver's cooling seat may not be working
Having just gotten my '17 a week ago, I hadn't had a passenger in my seat yet (wife was in Reno on a business trip). Tonight I turned off her seat cooler and I noticed a fan-sound turning off.
I have never noticed this on my seat, and frankly it doesn't seem to get cool in any identifiable way.
Where to begin? Fuses? Why would one blow unless there was more trouble somewhere else in the seat? Bad switch? How to test it?
I'll check the hot side tomorrow on the way to work. And I'll look under the seat to see if a wire came loose.
#69
Do you hear the fan motor running?
The seat back is clipped on, if you remove it you can access the fan. The clips break easier so have some spares handy. Here is a Tech Tip on seat back installation, I assume a 2017 is still applicable.
FOGeologist (08-16-23)
#70
#71
Also, i'll note, the fan is crazy weak in the GX, in comparison the 4Runner we have sucks air out pretty aggressively, however the similar seat, and fan arrangement in the GX is less than half as powerful. the GX fan, unsurprisingly, is much much quieter though.
#72
Biggest issue is the tiny port the air comes out of in the seat is more at the front rather the middle of the seat. That and lack of CFM's.
#73
I’ll go and evaluate it much more closely when I get into the truck this afternoon at work.
I guess it’s possible the fan may be out or I just haven’t evaluated the problem well enough to understand it - or even if there is a problem yet.
#75
Super Moderator
Harvested pictures from everywhere
Fan pic comparison 10-13 & 14+
Seat fan of a 10-13 model
I haven't had enough time to test but using 3D print from here.
This is where the air comes up at the seat and connects to the foam
