•• OBD Fusion/Link - Vehicle Diagnostic Tool
Old 12-18-19 | 10:55 AM
william489's Avatar
william489
Noticed A/T2 temp fluctuates more and at times higher than A/T1 temp. I am just curious why?
Old 12-18-19 | 02:10 PM
Acrad's Avatar
Acrad
Super Moderator
AT 1 is the pan temp and AT2 is the fluid outflow from the torque converter. Normal for 2 to get hotter than 1.
The following 4 users liked this post by Acrad:
AlexDev (07-01-23), bowhun2r (12-19-21), John00 (12-18-19), william489 (12-19-19)
Old 12-19-19 | 04:22 PM
william489's Avatar
william489
In case you want to know tire pressure of your GX with the help of mx+, below is the tire ID mapping
ID2 = driver front
ID3 = driver back
ID4 = passenger back
ID5 = passenger front
ID1 = spare
I also noticed that passenger side tire temp is consistently higher than driver side, probably to do with exhaust pipe? My tires are stock ones.
Old 12-19-19 | 04:27 PM
Acrad's Avatar
Acrad
Super Moderator
Remember... that can change around as you rotate tires so can be different on everyone's vehicles.
Mine are 1-spare / 2 - Driver Rear / 3 - Passenger Rear / 4- Driver Front / 5- Passenger Front
Not in your case but if you notice an abnormally higher temp on one tire and not in the sun it could be a sticking caliper.
Old 12-19-19 | 04:55 PM
bbqsoup's Avatar
bbqsoup
I need to find the time to deflate the tires to map them as I have no idea what is what except the spare.
I'm curious why your spare tire pressure goes up. Mine mostly stays the same
Old 12-19-19 | 08:55 PM
william489's Avatar
william489
My full size spare looks never used. Rotation has been done only at lexus dealership. Not sure if this is standard practice or they are just lazy not to include spare in rotation.
Old 12-19-19 | 09:03 PM
william489's Avatar
william489
I did 40psi for all 4 a few weeks back, so I dont have to add air during winter month. But temp has been quite mild this winter most of time. So it is around 38/39 these days.
Overall I prefer psi between 36 and 40 cold. I dont tow and load is just avg. However I heard higher psi improves on road handling in snow/rain condition.
Old 12-20-19 | 09:28 AM
Climber's Avatar
Climber
Hi Arcad,
In your first post you mention 2 apps: OBD Fusion and OBD Link. They seem to be from different companies (resp OC Tech LLC and OBD Solutions LLC), although some of their screens are identical. Do you know the differences? Is it the same company under different names? Which one are you using?
Does Carista still do more?
Regards,
Climber
Old 12-20-19 | 11:18 AM
Acrad's Avatar
Acrad
Super Moderator
OBD Link comes as a free download when you purchase one of their OBD adapters. Their OBD adapters will only work with OBD Link.
https://www.obdlink.com/mxp/
If you want to try using the software with your choice of OBD adapters you just purchase OBD Fusion. Same software development from what I can tell.
The advantage of OBD Link is you get all the $5-$10 add-ons for free while you have to purchase one for each model year and brand of vehicle with Fusion. If you only intend to use this with one vehicle Fusion would be the better deal.
They do update the firmware on their OBD Adapters... not something you see on the cheap OBD adapters out there.
Carista can program the personal settings like what can be done with Techstream. I've never used Carista with a vehicle in like 5 years or so. I don't remember it allowing you to create gauges... I think it is more targeted as simply a troubleshooting tool. IIRC.. tecman has Carista
Does this help?
Old 12-21-19 | 09:02 PM
Climber's Avatar
Climber
Yes, very helpful. Thank you.
Seeing that the OBD Link adapters start at $50 and I already have an ELM327 wifi adapter and so far only 2 cars with OBDII, I'm going to try Fusion on one.
Old 05-06-22 | 11:07 AM
308guru's Avatar
308guru
Default Who's using OBD Fusion & Veepeak OBDCheck BLE+
I was thinking of getting the OBD Fusion app & Veepeak OBDCheck BLE+ dongle to get info from my 2019GX and 2010 Highlander.
Just checking to see if anyone else is using this combo, how well it works, any quirks you've stumbled onto, etc.
I have an older wifi Veepeak dongle and that thing is simply a pain to get connected and many times I don't even remember how to with all of the setup that's involved. I'm looking to update to something newer and friendlier.
Thanks.
The following 2 users liked this post by 308guru:
Gxme99 (08-31-24), MrTorgue (05-06-22)
Old 05-06-22 | 01:02 PM
MrTorgue's Avatar
MrTorgue
My Veepeak doesn’t seem to connect to ANYTHING. I’d love to find one that will connect to my GROM Vline in my 460 so I can have Torque Pro fully display things like temp sensor readings and etc.
Old 05-06-22 | 01:36 PM
Acrad's Avatar
Acrad
Super Moderator
@MrTorgue
@bbqsoup using a genuine ELM chipset connected to his GROM
https://www.clublexus.com/forums/gx-...l#post11050246
Not sure how easy those are to find these day.
I believe he is referring to the same one I purchased from Romania
https://www.clublexus.com/forums/gx-...l#post10290270
I'm not sure I have heard of anyone getting the OBDLink MX+ working with a GROM. OBD Link is used in lieu of Fusion with this adapter. Every vehicle expansion pack is included with purchase so no need to purchase separately like in Fusion.
https://www.clublexus.com/forums/gx-...and-gx460.html
The following 2 users liked this post by Acrad:
bbqsoup (05-06-22), MrTorgue (05-06-22)
Old 05-06-22 | 01:48 PM
bbqsoup's Avatar
bbqsoup
I’ve seen many report that other OBDII would work too, even Veepeak.
However I have a generic one from Amazon and it doesn’t work with Grom but works with IOS.
Old 05-06-22 | 02:18 PM
308guru's Avatar
308guru
Which Veepeak do you have?
Quick Reply: •• OBD Fusion/Link - Vehicle Diagnostic Tool
