•• OBD Fusion/Link - Vehicle Diagnostic Tool
Old 07-20-23 | 04:33 PM
  #61
Misteracng's Avatar
Misteracng
I did the same with the OBDLink mx+, I have a 2023 and I set it as a 2021 and also chose the 2021 Lexus to get access
Acrad (07-20-23)
Old 07-21-23 | 06:50 AM
  #62
gfcipriani's Avatar
gfcipriani
Originally Posted by Acrad
The OBDLink app only works with their adapters but includes "ALL" of the automaker and year expansion packs. If you use adapter on a lot of vehicles it would quickly pay for itself. OBD Fusion works on non-OBDLink adapters (although you could use it with theirs) but you then have to purchase the expansion packs.
I would do what they suggested and please report back.
well, this worked. Had to delete my vehicle and re-add, this time as the 2021 GX 460. All the PIDs were added. I can now monitor AT temps and more. Thanks @Acrad
Acrad (07-21-23)
Old 08-15-23 | 09:00 AM
  #63
FOGeologist's Avatar
FOGeologist
Default Techstream and this dongle
Can this work with Techstream to Zero-Point Calibrate the Crawl Control?
If I want to install Crawl and MTS, can I use this dongle to calibrate CC after installation?
Or should I just use the paper-clip method?
Old 10-31-23 | 03:37 PM
  #64
dallen1059's Avatar
dallen1059
3rd Gear
Default 2023 OBD fusion advanced diagnostics
I can't seem to find advanced diagnostics package to buy for OBD Fusion. the latest i can find is for 2021.
Any ideas here?
Old 12-06-23 | 04:56 PM
  #65
xychromo's Avatar
xychromo
Remember... that can change around as you rotate tires so can be different on everyone's vehicles.
Mine are 1-spare / 2 - Driver Rear / 3 - Passenger Rear / 4- Driver Front / 5- Passenger Front
Not in your case but if you notice an abnormally higher temp on one tire and not in the sun it could be a sticking caliper.
Curious as to how you keep track of each tire ID in the event of a rotation? Do you just update the IDs listed in the dashboard at every rotation?
Old 02-13-24 | 05:27 PM
  #66
skey44's Avatar
skey44
2nd gear
I had two questions but one was already answered in this thread( inability to have trans temps and TPMs at same time). My next question that I haven’t seen the answer for is my tpms is showing in mmHG. How do I get to psi from there?
edit: found it in the preferences screen under setting 👍🏻
The following 2 users liked this post by skey44:
Acrad (02-14-24), JeffS520 (02-14-24)
Old 07-31-24 | 05:10 PM
  #67
Mantutuli's Avatar
Mantutuli
Is the MX+ still the preferred OBD2 reader?
Anyone use a TOPDON artilink 600?
Old 10-10-24 | 05:55 PM
  #68
ch99tj's Avatar
ch99tj
Originally Posted by bbqsoup
I went and filled it up today.
When the pump stopped at first click, the fuel gauge registered with 21.27gal.
I pumped it a bit more and at second click, it was 21.53gal.
I tested it at a few spots in Costco parking to make sure I was on a flat surface, all registered at 21.53.
When I pulled into my drive way at an incline the max it showed was 21.66. Usually on an incline it would show almost 2gal more when 1/2 full.
So the max it could show is 21.66 regardless how much gas is in the tank.
I cannot find where that transmission temperature node is. I've got mx+ adapter with the GX download for my model year
bigblack06
03-11-11 09:10 AM
Quick Reply: •• OBD Fusion/Link - Vehicle Diagnostic Tool
