•• OBD Fusion/Link - Vehicle Diagnostic Tool
Old 04-25-19 | 12:25 PM
Acrad's Avatar
Acrad
Super Moderator
Exclamation •• OBD Fusion/Link - Vehicle Diagnostic Tool
PID Screenshots
This app has been been discussed in a couple separate threads but I thought it might be good to bring it all together into one spot.
Collected data can be automatically saved in the app to a free "Dropbox".
[Threads]
TPMS
Transmission
Android - OBD Fusion
Android - OBD Link
IOS - OBD Fusion
IOS - OBD Link
Firmware revision history for the OBDLink MX+
It should work with any ELM327 adapter but it is $9.99 for every different year and vehicle you add to the program. This would be '96-Present for Ford, Lincoln, Mercury, Mazda, Nissan, Infiniti, Toyota, Lexus, Scion and GM
If you use one of their supported adapters you get full access to all years and vehicle brands above.
Amazon Amazon
https://www.obdlink.com/products/obdlink-mxp/
OBD Link adapter
So far it appears this is the best "portable" Techstream option for troubleshooting. Techstream has it's place with programming options but this clearly has a lot of advantages and is basically plug and play to get going. We can all help each other so much better when someone can pull the codes on an electronic failure. Otherwise it is often a guessing game.
I will eventually post a video of how to connect and setup but posts below will have screenshots of what functions can be monitored in gauges as this piece really isn't published.
•• No idea of everything in screenshots below are supported in 460 so report back on things that do and don't work.
•• You do need their adapter or genuine 2.x firmware ELM327 adapters to read TPMS.
PID Screenshorts
The following 4 users liked this post by Acrad:
cancruiser (08-30-22), ColdIron (12-10-23), Martyh (08-31-22), Philly01 (12-11-19)
Old 04-25-19 | 12:28 PM
Acrad's Avatar
Acrad
Super Moderator
Checking for codes and OBD Readiness
Click DIAGNOSTICS once connected
Old 04-25-19 | 12:35 PM
Acrad's Avatar
Acrad
Super Moderator
OBDLink MX+ Adapter
RESTORE TO FACTORY SETTINGS
Press and hold the button for 15 seconds
When factory settings have been restored, the green power LED will flash and turn solid
SLEEP MODE
While in sleep mode, the power LED quickly flashes every three seconds
Forum for device
Submit a Support Ticket
Old 04-25-19 | 01:52 PM
Acrad's Avatar
Acrad
Super Moderator
All sensor snapshots are in photo library above.
The following 2 users liked this post by Acrad:
cancruiser (08-30-22), PureDrifter (07-10-20)
Old 04-28-19 | 11:06 AM
Acrad's Avatar
Acrad
Super Moderator
Vendor told me once they fill out support for more brands they will work on the vehicle customization options like Carista has.
View AVS damper step changes
Old 07-12-19 | 02:38 PM
Acrad's Avatar
Acrad
Super Moderator
One item I have found this doesn't query or troubleshoot is the KDSS module. It will show up but no PIDs will be identified when scanning the module. Something developer is still trying to crack. If you become aware of any with other apps let me know.
ltsr (07-12-19)
Old 09-29-19 | 09:18 PM
Ramacher's Avatar
Ramacher
Is the MX+ worth the extra $30 over the LX? I'm seeing the only difference between the OBDLink LX and the MX+ is Single-Wire CAN (GMLAN) & Ford Medium-Speed CAN (MS-CAN)?
http://www.obdlink.com/mxp/
Old 09-30-19 | 01:34 PM
Acrad's Avatar
Acrad
Super Moderator
At the time time I picked up it was the only model of theirs that supported TPMS.
[Post 100] https://www.clublexus.com/forums/gx-...l#post10489499
You might to reach out to their support to see if the LX now supports this
"The MX+ currently supports TPMS. The OBDLink LX and OBDLink MX BT will support TPMS with a future update. We're hoping to release this update soon.""
••••The MX also gives you all the $10 add-on packs for free. If you plan to use on multiple cars it could save some money.
Old 11-03-19 | 08:27 AM
Acrad's Avatar
Acrad
Super Moderator
Anyone aware of any '14+ modules that are not found?
Is BSM on '14+ detected?
How about LDA, Radar Cruise, PCS on all years?
Old 12-11-19 | 03:11 PM
william489's Avatar
william489
I just tried my mx+, with obdlink app on my phone. I could not figure out how I can add tire pressure and AT temp on the dashboard. I did installed free add-on for my 2015 gx with no issues.
Also noticed power light stays green and Bluetooth light keeps blinking while car has been off for more than an hour. Hope it does not drain much battery
Thanks
Old 12-11-19 | 03:39 PM
Acrad's Avatar
Acrad
Super Moderator
Check in another hour or so... I have never timed it going to sleep but an hour seems like a long time.
You may need to reach out to support on that.
Does MX+ have latest firmware? SETTINGS ---> FIRMWARE UPDATE
Trying to do off memory and my phone no connect to vehicle
[Tire Pressure]
•Connect to "Tire Pressure Monitor" network when prompted
• Goto Dashboards
• Select MENU ---> Add Dashboard
• Select MENU ---> Add Display
• Digital Gauge
• Next
• PID
• Toyota, Lexus, Scion
• Tire Pressure Monitor
• ID Tire Inflation Pressure (you will have go through steps above starting at "Add Display" 5 times to get all TPMS sensors on that Dashboard you created.
Before going onto AT let me know how this goes.
Old 12-11-19 | 04:54 PM
william489's Avatar
william489
[Tire Pressure]
• Goto Dashboards
• Digital Gauge
• Next
• PID
Thanks a lot. This is very helpful. I just added all of these. Firmware updated too. Battery reading reduced to 11.7, I am bit concerned. Need to start engine and take a ride soon.
Old 12-11-19 | 05:02 PM
Acrad's Avatar
Acrad
Super Moderator
Device should goto sleep with no lights.
AT temps can be obtained selecting Generic since that also includes Network A
• Goto Dashboards
• Digital Gauge
• Next
• PID
• Engine and Electronic Controlled Transmission
Sensors
A/T Oil Temperature 1 <---This is pan
A/T Oil Temperature 2 . <--This is TC
AlexDev (07-01-23)
Old 12-11-19 | 05:23 PM
william489's Avatar
william489
• Goto Dashboards
• Digital Gauge
• Next
• PID
Sensors
Thanks. This works for me. Since my engine was not running then, I saw about 100F for at1 and at2.
Old 12-12-19 | 04:36 AM
william489's Avatar
william489
Trying to add pitch and roll, has not been successful on mx+ so far. Overall mx+ is awesome.
Quick Reply: •• OBD Fusion/Link - Vehicle Diagnostic Tool
