Rear Brakes and Pad Brands
Old 04-30-19, 09:36 AM
Nodal
Nodal's Avatar
Default Rear Brakes and Pad Brands
I need to replace the rear brake pad/Discs. What brand would you recommend?
Nodal is offline
Old 04-30-19, 10:38 AM
ObsidianBl
ObsidianBl's Avatar
OEM wouldn't be bad but some people "upgrade" and go with some aftermarket versions.
I searched using a 2014 GX, but the brake pads and rotors should be the same throughout. I'd also check amazon using the part numbers from RockAuto. Usually the shipping from Rockauto negates the savings.
https://www.rockauto.com/en/catalog/...brake+pad,1684
ObsidianBl is offline
Old 04-30-19, 10:40 AM
bbqsoup
bbqsoup's Avatar
I didn't replace the rear rotors but I used Akebono pads for both front and rear and they are good. Very good stopping power and quiet.
bbqsoup is offline
The following 2 users liked this post by bbqsoup:
DallasDave (05-01-19), John00 (05-19-19)
Old 05-01-19, 08:24 AM
JonGX
JonGX's Avatar
I just did mine and used all Toyota branded OEM parts (rotors/pads). Bought everything as a single order on eBay from a Toyota dealer in FL.
JonGX is offline
Old 05-01-19, 03:19 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,637 Likes on 2,383 Posts
Admittedly... just did a pad slap on mine but OEM pads. It was such low mileage when I did it that I didn't swap rotors.
Acrad is offline
Craigyyy (05-02-19)
Old 05-01-19, 03:21 PM
JonGX
JonGX's Avatar
i had 46k on mine but the rear pads had worn slightly unevenly and the clip gouged the rotor on the passenger side so I had to replace the rotors also.
JonGX is offline
Old 05-01-19, 03:33 PM
Acrad
Super Moderator
Acrad's Avatar
Rotors were fine on mine but lots of even wear all around. Either a brake rider or saw lots of time in the city in CA. My GX came out of southern CA and most of the saved nav spots from previous owner (dealer didn't reset) were from Santa Monica and Los Angeles area. In female body building circles previous owner appears to be well known online.
Acrad is offline
Old 05-02-19, 08:41 AM
Craigyyy
Craigyyy's Avatar
I would go with OEM. The quality is good and the price is right.
I also just did pads all around, kept my rotors. Brakes feel great.
Use plenty of grease. I'd also recommend picking up new OEM pad shims, also cheap.
Craigyyy is offline
Old 05-02-19, 08:49 AM
JonGX
JonGX's Avatar
Good reminder about the shims. I got OEM rotors, pads, and shims for $220. I thought this was pretty reasonable and is one of the things I appreciate about the Lexus - often you're just buying Toyota parts.
JonGX is offline
Craigyyy (05-02-19)
Old 05-03-19, 06:47 AM
Moonlite
Moonlite's Avatar
At 52k miles. I bought front and rear OEM pads from EBAY for $95 with $180 labor, and feel great as well.
Moonlite is offline
Craigyyy (05-21-19)
Old 05-03-19, 09:33 AM
John00
John00's Avatar
I recommend Akebono ACT with Centric Premium (and with E coat if available).
John00 is offline
Old 05-03-19, 10:05 AM
grammo
grammo's Avatar
What akebono part numbers did you guys use? I was trying to find them but I just went with the power stop evo sport pads up front because I couldn't find a akebono part number for a 2017 GX. The power stops are quite a bit more dusty than the akebonos I have used previously
grammo is offline
Old 05-03-19, 11:59 AM
bbqsoup
bbqsoup's Avatar
I forgot to take a picture but I believe they are Akebono ACT Ultra Premium for both Front and Rear
Similar to the parts here
https://www.partsgeek.com/mmparts/br...xus/gx460.html
bbqsoup is offline
Old 05-07-19, 05:56 PM
John00
John00's Avatar
front:
Akebono ACT976 Centric 120.44174
rear:
Akebono ACT606 Centric 120.44175
I dont think that on our GX460 would see any benefit from the Akebono ASP version, plus it would make more dust.
John00 is offline
grammo (05-07-19)
Old 05-07-19, 10:43 PM
ROSCOGX470
ROSCOGX470's Avatar
+1 on OEM pads. I did however use the Akebono pads on the front the last time because I had a credit from TireRack and it was basically free. They are nice pads but the anti squeal clips are cheap and don’t fit great. I bought a set of OEM from Lexus and will use on next pads install.
ROSCOGX470 is offline
Quick Reply: Rear Brakes and Pad Brands
