Looking for some advice on AT tires for the Gx460
#46
Cooper AT3 are good tires and quiet and have good wet traction but i think their rubber is a bit soft and wear out fast. They are also easy to feather if the psi isn't right.
#47
I personally experienced a brand new set to be out of round. Battled with Michelin tech support over it for a few days. My next set? same problem. I know people personally who also had the problem. In reality, it's probably just a small number of people out of the thousands they sell that has experience this issue -- I know you were being sarcastic and wanted to troll since you hate @ASE . It's personally disappointing since I have owned 2 sets of the original BFG KO and wore them down to the end and loved them.
#48
the original post was for AT tires for wet and sand. one option for wet and sand is to not use AT tires. even though the post was about AT tires, I'll throw this out there just in case it helps someone. For wet and sand AT isn't the optimal design. For wet, you dont want a tire with a bunch of block patches of rubber like an AT tire. For sand you dont want something designed to DIG in like an AT tire.
heres something better for wet and sand and even snow. its a summer based tire with the 3 mountain peak for winter, and has a way better tread for sand than an AT tire.
#49
As an aside, there is no such thing as a "summer tire with 3 mountain peaks"
That said and a bit of a hijack - is there a tire that will provide superior snow traction AND acceptable handling and wear in summer months?
#50
Gotta love the guy (or gal) that says "here's a better tire" and never identifies it...
the tire is identified in the pic. for those who cant see it for some reason, its a michelin cross climate suv
i said summer based tire, not a summer tire. read up on it. its an all season tire, based on the previous summer tire, with the 3 mountain peaks.
this is the tire that will provide superior snow traction AND acceptable handling and wear in summer months
theres a reason its the only tire legal year round in some locations.
#51
#52
not saying this is illegal to run year round. saying that it is the only tire that is legal to run year round for some, at least when i did the research.
the tire was designed for northern european markets where you have to have snow tires on certain dates.
this is the tire that came oem on some mercedes so they wouldnt have to change the tires twice a year in those markets.
#53
Thanks for the info.
Do you run these year-round? Any ideas of tread life if rotated properly?
#54
Some Canadian provinces have adopted the same requirements.
#55
if you click on the pic it should get bigger, at least it does for me.
ive had them only since this summer. others have said that they wear ok but not as good as some tires. my guess is that the tire might be softer to get the good cold response and this could shorten life. but it is meant for year round use. i drive on gravel so my wear might not be a good example but ill recheck after one year.
a friends dad has them also, said he likes them and didnt mention wear as a problem.
seems the more traction you get the faster they wear in most cases.
i asked the discount tire guy where i got them, he didnt know much about these since they arent that popular. most people dont even know about them.
heres results from a tirerack survey. they have reviews maybe theres a clue in there. the most impressive set of scores i remember ever seeing. maybe skewed due to smaller population, dont know.
#56
yeah #1
one more note, they make about zero noise until you turn. then they make a strange swooshing sound you can hear if the windows are down. really neat to hear, and can hear it at very low speeds.
to me it sounds like traction. i havent noticed a decrease in mpg.
#57
Yes, they have pretty decent reviews.
On my current car, I run dedicated winters during the winter and high performance all seasons the rest of the time since I need to be mobile 24/7 and am getting too old to be a speed demon in hairpin turns.
#58
Ahhh, the sweet sound of traction.
I ran winters and all seasons as well. im hopeful that they will work out well year round. so far they are. excellent in the rain, in the hot and dry too. didnt even slip on the interstate in the rain over the tar patches.
#60
Heydreezy
05-13-11 05:42 PM
