Preparing for road trip, should I be worried?
I've had my 2010 GX460 for a few months now and am getting ready to take it on its first road trip. It has 88k and will be getting the 90k service before making the trek. The only thing I'm worried about is the possibility of the secondary air injection pump unexpectedly failing during the trip.
From my understanding, the pump only starts when it is cold (correct me if I'm wrong). Temperatures will be 60 degrees plus the entire time. Would you be worried?
Dont' fret....
Do you have a OBD Reader? Users here have shown that you can reset out of limp mode resetting codes if this issue shows up.
To stay out of limp mode in event of a failure disconnect the air pump and reset codes. You will still have a Check Engine Light but it won't go into limp.
Air pump is located under that front cover over radiator and near the power steering reservoir and windshield washer fill. Either remove before trip or take a tool which you can use to remove all of those retainer clips.
I have a post here showing connector to disconnect, Let me find and I will add to thread.
Thanks for the detail. I'll order an OBD reader and do the UNI mod before we leave. That will be way cheaper than keeping a bypass kit on hand and will make me feel better about not having to limp there or back!
Acrad (05-19-19)
Any 1" filter will do
What most people got
Cheaper version
https://www.amazon.com/Uni-Filter-UP-107-Clamp-Breather/dp/B003CJOTSA/ref=sr_1_1?crid=168IL9L5ETRT0&keywords=1+uni+filter&qid=1558458107&s=gateway&sprefix=1%22+uni%2Caps%2C182&sr=8-1
Cheaper version
https://www.amazon.com/uxcell-a16081500ux0518-Mushroom-Intake-Breather/dp/B01NATUWVN/ref=sr_1_10?crid=168IL9L5ETRT0&keywords=1+uni+filter&qid=1558458053&s=gateway&sprefix=1%22+uni%2Caps%2C182&sr=8-10
O the filter mod. I thought they were referring to changing the actual foam inside of the pump before it deteriorates.
https://www.amazon.com/Uni-Filter-UP...s%2C182&sr=8-1
Cheaper version
https://www.amazon.com/uxcell-a16081...%2C182&sr=8-10
Cheaper version
Dropped it off for service this morning and the first thing he said is, "Oh! Looks like there's an open recall for the secondary air injection pump, I'm going to check on that and see if we can replace it while it's getting serviced."
Crossing my fingers.
If they do fix...bonus.... but if not a cheap less than $20 option is just a cheap OBD2 reader to reset codes.
Cheaper version
Cheaper version
