OEM AT Cooler Install
Old 05-26-19, 12:09 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,668 Likes on 2,401 Posts
Old 05-26-19, 12:18 PM
Acrad
Super Moderator
Acrad's Avatar
The following 4 users liked this post by Acrad:
Mazderati (05-11-20), notmill (04-24-22), panardog (01-03-23), Rick111 (03-12-21)
Old 05-29-19, 02:05 PM
Acrad
Super Moderator
Acrad's Avatar
I received my AT cooler from Megazip today. It actually came last Friday but was out of town.
The following 6 users liked this post by Acrad:
hzhao (05-29-19), ltsr (05-29-19), Mazderati (05-11-20), Rick111 (03-12-21), Romanova (05-29-19), tuandino (01-07-20) and 1 others liked this post. (Show less...)
Old 06-01-19, 03:34 PM
Acrad
Super Moderator
Acrad's Avatar
Washed rig this morning then thought I would tackle at least the staging piece of the AT cooler install.
The reason for my little shout out on F-Sport grill thread before I figured it out.. Installing the AT cooler is easiest with grill out of the way.
This was just getting the cooler mounted in front of radiator, installing the pass through connector, connecting hoses from cooler to pass through and putting some covers on the internal connectors that are not connected on the inside of engine area.
Some observations:
• I may have bought one too many hoses. The existing hose from AT to the top connection of AT cooler in radiator will probably just stay in place.
• Not sure that foam piece is actually needed. I assume it goes on the inside but didn't fit very well. I might look tomorrow and turn it around. The pass through is held in with a bolt so not sure it really does anything beneficial. You also remove the existing foam covers that cover that pass through area. I end up removing the top foam piece first and then realized my mistake that it was the bottom on that was needed for removal. Oh well.. a little extra cooling.
• I will most likely need to remove front skid to disconnect the AT return line which is replaced with this mode. In addition I think I will remove the battery to get my arms down in there to disconnect all the old hoses.
• What is left to do:
- Disconnect outlet of water cooler AT line and connect with new hose to pass through connector
- Connect new AT return line from pass through to connector at bottom of the radiator
- Account for additional fluid needed by cooler so will probably do one more drain and fill of AT fluid.
Just a few pics.
The following 10 users liked this post by Acrad:
bbqsoup (06-02-19), cridel (08-01-22), hzhao (06-01-19), ltsr (06-02-19), Mazderati (05-11-20), Mojlnir (06-01-19), Rick111 (03-12-21), Romanova (06-01-19), Slprciv (09-11-21), tecman (06-01-19) and 5 others liked this post. (Show less...)
Old 06-01-19, 04:51 PM
Romanova
Romanova's Avatar
Great stuff! Looks relatively straight forward also...
Old 06-01-19, 04:58 PM
Acrad
Super Moderator
Acrad's Avatar
It really does. I like the fact everything has been plug and play so far and all stock screw mounts are already there. They even put paint marks on the hoses which are listed in instructions and clearly show what needs to be connected to what.
Slprciv (09-11-21)
Old 06-03-19, 09:14 AM
RedRacer
RedRacer's Avatar
Nice upgrade. What is the approx total cost for all the required parts?
Old 06-03-19, 05:29 PM
Acrad
Super Moderator
Acrad's Avatar
Granted a 3rd party cooler would be much..much cheaper but wanted something plug and play not requiring any customizations or equipment relocations.
Minus one hose that shouldn't be needed this package cost me around $400... if one went with 3rd party cooler they could probably drop $100 off of it.
Old 06-06-19, 06:31 AM
Jacket
Jacket's Avatar
Nice project. $400 isn't that bad for a full OEM install. I do find it odd how Toyota/Lexus picks and chooses which parts and options to include in different markets. I can't help but feel like many of the US omissions are all about weight loss and trying eek out tenths of MPG's for gas mileage regulations.
Acrad (06-06-19)
Old 06-06-19, 03:22 PM
Acrad
Super Moderator
Acrad's Avatar
I will probably make the final terminating connections next week. I want to get one more solid temperature baseline without it with OBD Link to my cabin.
In addition to stats installed I want to see the further influence of pinning AT thermostatic switch open.
Old 06-14-19, 12:12 PM
Acrad
Super Moderator
Acrad's Avatar
Finished this project today and did my 4th AT drain and fill. This was to also ensure I was at correct quantity with cooler in place.
- Stock hose from AT to radiator can stay. I need to update parts list on first post.
- If KDSS shock wasn't there it would be far easier to get your hand in this area.
- You will need to cut a rubber piece that hold the inlet/outlet hoses together. If you look down the AT lines you will see it. Just use a razor knife pointed outward, go slow and you will cut it.
- Need to drop the front skid. Trickiest piece was getting the hose off and on the return line below radiator. When you do put new hose back online be sure to stage the retaining clip (if using OEM) on the metal return line first as it won't slip over the entire run of hose from the top. I thought I was going to need to remove battery but I didn't have to.
- Temps of AT Pan have dropped around 20-25 degrees. Also TC probe cools down way faster. I went out and found hills to heat it up and solid 20-25 degrees less. I will have comparable data the following weekend when I go over the pass again. Feeling good about this mod.
- Take your time throughout project.
- I will also report back how much further temps can drop with AT thermostat pegged open.
The following 8 users liked this post by Acrad:
hzhao (06-14-19), JoshDrivin (08-14-20), Lavrishevo (05-08-20), ltsr (06-15-19), Mazderati (05-11-20), Mojlnir (06-15-19), Rick111 (03-12-21), Slprciv (09-11-21) and 3 others liked this post. (Show less...)
Old 06-15-19, 07:17 AM
krazykrnbo
krazykrnbo's Avatar
Thanks for the guide!!!!!. Definitely something to consider if you're towing
Old 06-16-19, 11:18 AM
Acrad
Super Moderator
Acrad's Avatar
I pinned the thermostat open today and put it through some good hill climbs.... extremely short TC temp spikes up to maybe 205°F that rapidly cooled off. I couldn't get the pan temp to go over 187°F
Might even be too cool for winter with that thermostat open but summertime towing this would address any of my AT temp concerns.
Also seemingly more cooling at stopped idle where I assume the fan clutch is engaged and it is pulling extra air through on the cooler.
Old 06-17-19, 12:53 PM
KVA
KVA's Avatar
Nice! Way to take one for the team...lol. Looking to do the same upgrade now. Just need a correct parts list of what you actually used.
Acrad (06-17-19)
Old 06-17-19, 01:19 PM
Acrad
Super Moderator
Acrad's Avatar
Here is what I used. Minus one less hose and a couple clamps from my original list.
32943-35050 QTY:1 (NO. 4 OIL COOLER OUTLET HOSE)
32943-35060 QTY:1 (NO. 6 OIL COOLER OUTLET HOSE)
90119-06336 QTY:4 (On install steps bolts used on step one to attach all pieces but item listed as #1)
90080-11589 QTY:2 (On install steps bolts used to attach #1 on step one and step 2
NO. 3 OIL COOLER TUBE SUB-ASSEMBLY. This subassembly bolts to the cooler bracket)
90466-16004 QTY:8 (Hose clamps)
32948-60020 QTY:1 (Foam Seal for NO. 3 OIL COOLER TUBE SUB-ASSEMBLY)
32913-60260 QTY:1 (Driver side attached bracket to cooler)
32913-60270 QTY:1 (Lower attached bracket to cooler)
32943-60610 QTY:1 (NO. 5 OIL COOLER INLET HOSE)
32943-60620 QTY:1 (NO. 5 OIL COOLER OUTLET HOSE)
32907-60290 QTY:1 (NO. 3 OIL COOLER TUBE SUB-ASSEMBLY)
and purchased the AT cooler from Megazip. https://www.megazip.net/zapchasti-dl...oil-3291060171
BobSwagger (02-09-21), Dna32746 (12-30-22), GX4602011 (06-21-19), JoshDrivin (08-14-20), KVA (06-17-19), Mazderati (05-11-20), nuclearn8 (06-20-19), Philly01 (05-10-20), Rick111 (03-12-21), Slprciv (09-11-21) and 5 others liked this post. (Show less...)
Quick Reply: OEM AT Cooler Install
