Unfortunately I don't even see that bulb listed in the FSM. They show service of pulling the headlight assembly and replacing high beam bulb but nothing related the the parking light. Is that a LED or can you confirm an incandescent bulb?
Thank you! I believe this is the incandescent bulb I'd like to replace with the LED. I was referring to this thread when people changing front parking lights to LEDs (https://www.clublexus.com/forums/sho....php?p=6086032) The front "yellow" side parking bulb ...
Could you please suggest easy access to replace front parking light bulb on 2018 GX? Thank you!
I believe for 2014+, the front parking/side marking lights are LED, and they are part of front light assembly. The rear side marking/parking lights are T-10 bulb, which you can replace with LED.
Got it! Thank you very much for your response to this!
