Hello,
New here. I just bought a used GX and have some oversized BFG's that only rub on the passenger side inside part of the wheel well where the running boards connect to a piece of black plastic on the inside of the wheel. This has caused the factory screw and plastic fastening to break. Should I try to tac down the plastic so that it is flush or just trim the fat? Any recommendations on how to have this piece sit flat and secure would be welcomed. Images attached. Thank you.
Sorry....I'm not sure on post damage repairs... I have heard of some using a heat gun to mold things back before or shortly afterward as they were putting on the larger tires and noticed the rub.
You might have to use some heat to get it out of the way and then look for some misc hardware bolt, hardware and nut to reattach. I don't know offhand if that bolt just threads into something like this
