Techstream
Old 04-08-19, 09:56 PM
  #61
Gxxr
Gxxr's Avatar
Default Techstream - Question about Java Runtime Environment
Hello Gang,
I am trying to run techstream, but I don't have a Java Runtime Environment 6 or 7 installed, and I can't seem to find where to download it from Oracle, even after joining Oracle....... it looks like it is no longer available.
Any Oracle users here or I.T. guru's help me out?
When I run techstream, and it says it is connecting with my cable, and it shows the vehicle VIN, but all of the boxes for everything is yellow, and when I try to run a test (like testing the daytime driving lights), it shows a windows error and shuts Techstream down.
Old 04-09-19, 05:05 AM
  #62
hzhao
hzhao's Avatar
Originally Posted by Gxxr
Hello Gang,
Need more information to diagnose, such as windows version, OS platform, etc. As far as the JAVA runtime, I believer it is not specific to version 6 or 7, any current version and service level should be fine.
Old 04-09-19, 07:11 AM
  #63
NewB2Lexus
NewB2Lexus's Avatar
The Java Runtime is backwards compatible (more or less, but running any end user app it should be). Just download the latest released version if you don't have one.
Old 04-09-19, 02:13 PM
  #64
UZ214
UZ214's Avatar
have to agree, I installed tech-stream on an older Sony laptop running windows xp. Worked like a champ have used to program keys, reset brake system etc.
Old 04-09-19, 02:36 PM
  #65
Gxxr
Gxxr's Avatar
Yeah, I am running a Panasonic Toughbook CF-30 with Windows XP 2002 SP3.
I have tried multiple times to load Java and it won’t work.
Old 04-09-19, 02:42 PM
  #66
Acrad
Super Moderator
Acrad's Avatar
Received 3,654 Likes on 2,392 Posts
Are you performing a Techstream application install or this Virtualbox VM install?
https://forum.ih8mud.com/threads/how...nutes.1034923/
Old 04-10-19, 01:09 PM
  #67
bambam2
bambam2's Avatar
I believe I just downloaded the latest version from java.com and it worked, but I'm also using a laptop with Windows 10.
Old 04-10-19, 09:49 PM
  #68
Gxxr
Gxxr's Avatar
I had a much longer version of my email that got dumped..... cliff notes - I was running a version 13.2 of Techstream that came with the Mini-VCi, but it required java runtime environment v 6 or higher, but I couldn't get java to download onto my laptop with firefox, tried opera, and it acts like it is opening, then nothing......
I deleted my version of Techstream and decided to give the Virtual Box a try. 4 hours later, I had the Techstream image downloaded with Mega and I got it uploaded to the virtual box. I set the virtual box to run as a Windows XP 32 bit machine.
I have attached images of the error I get when I try to start the Oracle Virtual Box after about 4 hours of work last night.....
I have rebooted multiple times with the same exact error message. I am usually pretty smart about this stuff, but not this time.....
Old 04-12-19, 02:58 PM
  #69
Acrad
Super Moderator
Acrad's Avatar
Would you happen to have a Window 7, 10 or Mac OS X laptop sitting around?
Since XP support went off the radar back in April 2014 compatibility with Java and this Virtualbox could be highly doubtful. I only tested Virtualbox on a 10.13.x OS X laptop.
I think at this point the 32-bit TS installs that are being sold probably load fine with XP but I have my doubts that Virtualbox will play nicely seeing errors you are showing.
Old 04-13-19, 02:50 PM
  #70
tecman
tecman's Avatar
Where did you guys get the registration key from? The Ebay seller put it in the description but it doesn't work. The software ID is different so that makes sense. I reached out to the seller and all they know is what they posted. I found a registration crack that requires a download and that concerns me. I am using an old Windows 7 laptop that has no real info on it so it is an option.
http://blog.eobdtool.co.uk/toyota-ti...-pass-cracked/
From the seller..
Version Techstream V13.10.019 with original registration keys for 5000 days, no need to use patched program (replace original exe file first) any more, it maybe cause of live data problem! We will send four original registration keys to you.
V13.10.019
Software ID:32AED5D21FE321AE515AD321C3545A1D
Registration Keys
Japan: 1594e524cd96040064181500c9d19f254d21cee243de95
Europ: 04eb1b13f84ad4c6b1333fd2405a9be950001806150442
Other: 3b740263b7a71bab7e8d5695ff869c1b50001806150442
North America: d00ab6d2488ceb8132acf44f7d19c65150001806150442
If you have any problems, please use contact(s) from enclosed instruction.
Package Contents:
-1xV2.0.4 Mini VCI diagnostic cable
-1xMini Disc with:
* VCI driver
* Step by step txt instruction and Video instruction
* Techstream User Manual(English,German,Spanish,French,Japanese)
* Techstream V13.10.019 use original program files,give us software ID first and wait one working days for the keys.
* Techstream V13.00.022 (follow the txt/video instruction step by step,install and activate program by yourself,then can test car at once,No waitting.
* Techstream V10.10 and V10.30 are backup programs for few very old cars
Screen shot of my Techstream
Old 04-15-19, 06:13 PM
  #71
axman07
axman07's Avatar
I picked up a Carista the other day. Although many toyota / lexus models have TPMS support - unfortunately the GX460 is not one of them. I sent an email to the company as to when/if they plan to add TPMS support for the GX. Seems silly as it's essentially the only lexus without TPMS support. I look into toyota and the sister 4runner is one of the only Toyota models without TPMS support as well. Perhaps there's something 'unique' with our setup? Either way - it's a bummer as using the carista app is sure simple and quick.
Acrad (04-15-19)
Old 04-15-19, 06:27 PM
  #72
Acrad
Super Moderator
Acrad's Avatar
Thanks for heads up about Carista and TPMS.
Old 04-19-19, 12:26 AM
  #73
Acrad
Super Moderator
Acrad's Avatar
This is an interesting Carista note here as I needed an OBD cable with K-Line support for live data using Techstream.
https://caristaapp.com/help#why-does...-and-vw-models
axman07 (09-13-19)
Old 04-27-19, 11:38 AM
  #74
Acrad
Super Moderator
Acrad's Avatar
There is the brake bleeding option with TS
I see there are options to check on cylinder compression as well.
hzhao (04-27-19)
Old 06-13-19, 06:22 AM
  #75
brian4l
brian4l's Avatar
Default Techstream
This work for anyone? Anyone have any other affordable, safe options for Techstream on your GX?
https://www.amazon.com/TOPEMAI-Firmware-Software-V13-10-019-Techstream/dp/B07SLX5V1Y/ref=sr_1_4?keywords=TOYOTA+techstream&qid=1560432057&s=electronics&sr=1-4 https://www.amazon.com/TOPEMAI-Firmware-Software-V13-10-019-Techstream/dp/B07SLX5V1Y/ref=sr_1_4?keywords=TOYOTA+techstream&qid=1560432057&s=electronics&sr=1-4
Quick Reply: Techstream
