Techstream
#106
I gave the tire guy the specs of the car but the ID showed up as decimal. I wasn't really paying attention when he scanned all the wheels and took the pictures. I've been going back and forth on getting the autel device. I don't have much use for it anymore since I know all the tpms id codes for my vehicles... But it's always nice buying new tools. How do you like it and what model did you get? I've heard they can only program using their own TPMS sensors.
#107
Super Moderator
#108
Techstream Setting to disable smart key proximity sensor?
Hello, anyone know the techstream setting to disable the smart key proximity sensor? I am wanting to do so to discourage the smart key relay-attack. I know many of you have your opinions on this matter but I am asking for responses on correct setting in techstream. Thanx in advance.
maduro
14 GX Premium
maduro
14 GX Premium
#109
Super Moderator
That should be in your Door Lock Settings in infotainment
https://www.lexus.com/pdf/service/MY...on-Display.pdf
#110
Thanks acrad......that did the trick. I've now disabled the smart key sensor and no longer worry about walking out to an empty driveway. I can no longer use my credit card smart key but only a minor loss.
#111
Super Moderator
This device was reported from a GXOR member to have basically full Techstream functionality. It can even perform active tests.
http://www.facebook.com/groups/Lexus...6723491792084/
NewB2Lexus (09-20-21)
#112
Super Moderator
2010-2013 Customizations
#113
Super Moderator
#114
Super Moderator
#115
Mongoose and Techstream Lite?
How would I go about buying this for a '22 GX? I see the Mongoose is $500 but how do I go about buying Techstream Lite?
#116
There are some very inexpensive, but good, choices available on Amazon...
Look for MiniVCI
There is also an excellent write-up on how to get and use a VM-based TechStream in the Forums here, too... please use the search feature.
Look for MiniVCI
#117
The folding mirror feature isn't available via TS, it's the aftermarket ODB add on. You can use TS to turn off the steering wheel telescoping when exiting/entering the car, turn off seat belt chime and program the doors to be rolled down via the remote and a bunch of other stuffs.
#118
Super Moderator
v12 w/1.4.1 should work....biggest difference between 1.4.1 and 2.0.4 from my experience was you couldn't view live engine data with 1.4.1.
william489 (04-17-22)
#119
In my case, TS v10.30.029 and 1.4.1 firmware/cable worked to disable auto tilt-away of my 2015 GX. It is quick 2 min work if not less.
However, I found out that TS v12.xx.xx doesn't work for me and customization menu is missing, as reported by this post (https://www.clublexus.com/forums/ls-...-settings.html)
