Mark Levinson (ML) discussion / questions / problems
Old 11-08-20, 06:37 PM
  #196
1CrzyStory
1CrzyStory's Avatar
Originally Posted by oldgx460
Has anyone replaced the ML subwoofer and used the existing enclosure? My sub has popped and I don’t think it can be saved so I was hoping some people have swapped them out with a JVC, JL, Kicker, whatever brand with good results.
I replaced mine with an 8inch kicker sub.
Old 11-27-20, 09:20 AM
  #197
Acrad
Super Moderator
Acrad's Avatar
Received 3,652 Likes on 2,391 Posts
Old 11-28-20, 03:59 PM
  #198
Acrad
Super Moderator
Acrad's Avatar
https://www.marklevinson.com/in-lexus.html#gx
AFAIK... amplifier is still back near the subwoofer for '20+
Old 03-27-21, 12:18 PM
  #199
Shaq32
Shaq32's Avatar
Default Gx460 noise from the trunk area.
Hey all, I bought a 2011 GX460 premium with 100k miles on it. One thing I noticed is a weird whining noise coming from the back left side of the car (drivers side). I have pin pointed it to the rear left side all the way where a speaker is located. Can anyone help?
the seats are all the way down, and its not the fuel pump. not sure where the amp is located but could it be a fan on the amp if its located there ? thanks for any input
Old 03-27-21, 02:36 PM
  #200
tecman
tecman's Avatar
This happens with any power turned on, accessory power with everything related turned off and engine not running?
Old 03-27-21, 02:56 PM
  #201
Shaq32
Shaq32's Avatar
only happens when the car is on
Old 03-27-21, 02:57 PM
  #202
Shaq32
Shaq32's Avatar
when the car is on and being driven
Old 03-27-21, 03:26 PM
  #203
tecman
tecman's Avatar
Changes at higher speeds so possible wind noise?
https://www.clublexus.com/forums/gx-...t-rattles.html
Old 03-27-21, 09:13 PM
  #204
Shaq32
Shaq32's Avatar
No its not that. So I went and started the car on again. The sound also comes when I press the on button twice, when the engine is off as well. any other ideas what it could be ?
otherwise it seems like I'm going to have to open the drivers side rear inner panel. Any one have any links on how to open it? im scared to do it since I just bough it lol unless i can solve the problem
Old 03-28-21, 07:20 AM
  #205
Acrad
Super Moderator
Acrad's Avatar
Do you have the Mark Levinson? The amp & subwoofer in are in that area in cargo area above left rear wheel.
https://www.clublexus.com/forums/gx-...-proofing.html
Old 03-28-21, 11:44 AM
  #206
Shaq32
Shaq32's Avatar
That's gotta be it, its either the fans from the amp or the speaker. Is it east to pry open and put back together ?
Old 03-28-21, 12:02 PM
  #207
Shaq32
Shaq32's Avatar
yes it is Mark Levinson amp. Is this noise a common issue ?
Old 03-28-21, 12:22 PM
  #208
Acrad
Super Moderator
Acrad's Avatar
I have never noticed on mine w/ML.
I don't recall anyone else mentioning it over the years.
Old 03-28-21, 12:50 PM
  #209
Acrad
Super Moderator
Acrad's Avatar
Here are instructions from FSM on removal
The following 3 users liked this post by Acrad:
IanB2 (03-28-21), mail2anoopmv (12-25-23), panardog (01-03-23)
Old 03-28-21, 08:44 PM
  #210
Shaq32
Shaq32's Avatar
Thank you good sir!
Quick Reply: Mark Levinson (ML) discussion / questions / problems
