Mark Levinson (ML) discussion / questions / problems
#271
The stereo in my ‘19 was outstanding. Full, rich, LOUD when called upon. After a day and a half, my impression is that it was better than my new Mark Levinson.
Yes I’ve played around with the three-channel “equalizer” and other settings. Not bad. Not at all. Just may not be better.
darkoozy (06-18-23)
#272
Hi MikeP1, I found the quality of input makes a difference in my 22 GX with ML. I stream from iTunes (and use a wired connection to the infotainment system) in my GX and have set cellular streaming & 5G quality to Lossless. That seemed to make a noticeable difference (to me) in the sound coming out of the ML.
Best.
Best.
#273
Thank you. I was using wired connection and playing iTunes selections through CarPlay.
I’m asking the next question in case others may benefit. I cannot find a “lossless” selection in my controls. Can you advise?
Another note. Surround on/off makes a big difference and which one might consider better seems contingent on the individual music selection.
#274
MikeP1,
In iOS, Settings, Music, Audio Quality. You should find an option for Lossless Audio (I have this turned "on") and Cellular Streaming, 5G & Wi-Fi Streaming and Downloads.
I have Cellular Streaming, 5G & Wi-Fi Streaming set to "Lossless"
Hope this helps.
Best
Hope this helps.
Best
carlmock
01-25-06 02:58 PM
14, 17, 2007, 2009, 2010, 2014, 350, 450h, 460, amp, audio, axxess, base, cd, covers, dealer, difference, drive, es, fine, gs, gx, gx 460, gx460, hard, install, is250, levinson, levison, lexus, lexusmark, location, ls, lsound, mack, marc, mark, mark levinson, maunal, music, myis, placement, playback, player, position, premium, rattle, size, songs, sound, speaker, speakers, specification, standard, stereo, stock, store, subwoofer, system, tonneau, upgrading, vs, woofer
