Mark Levinson (ML) discussion / questions / problems
Old 12-13-18, 07:39 AM
  #106
lionsfan54
lionsfan54's Avatar
Originally Posted by bd5400
This is what I did with mine.
Depending on how loud you play music you may need to do both sides, not just the side where the sub is.
In my experience, it's nearly impossible to have too much Dyna-mat. Go nuts with it!
Old 12-13-18, 07:44 AM
  #107
John00
John00's Avatar
Originally Posted by lionsfan54
Before all that hassle I'd take that area apart and slather everything with Dyna-mat. Way cheaper
Good advice. Not only will it hopefully stop rattles, in some cases it can be applied in a way to let less sound escape, therefore more for you.
Old 12-13-18, 07:52 AM
  #108
lionsfan54
lionsfan54's Avatar
Yes. And, even with no stereo on, it will cut out some road noise which is always a good thing.
If I was mega rich, I'd have my entire car mat'd from front to back the day I picked it up.
Old 12-15-18, 05:58 PM
  #109
John00
John00's Avatar
This has all you could ask for. A wide range of low frequencies, nuns with guns, no need to go on after nuns with guns. Can find rattles all over the GX. Bluetooth into the ML from your phone and try it out. VOL <30 until you tweak the settings
Old 12-15-18, 07:01 PM
  #110
tecman
tecman's Avatar
Nice beat, my neighbor is probably annoyed as this is cranked with my sub kickin...
Old 12-16-18, 06:06 AM
  #111
John00
John00's Avatar
Believe it or not, the cheapest el cheapo all in one sub combo box gets good reviews. imagine having this in a GX with the cabin air volume making it sound good then they see what it was
Old 12-16-18, 06:12 AM
  #112
John00
John00's Avatar
looks like this guy, but im sure the generic speaker sounds better without the echo around 1:45
Old 12-16-18, 09:37 AM
  #113
mental69
6th Gear
mental69's Avatar
Default Thanks for all the input
The sub was rattling because one of the mounts that secures it to the frame had snapped loose. The fix we plan to do is to make a new enclosure in there using some "slurrie" - kind of a polymer/fiberglass mix. Should do the trick.
Cheers
Casey
The following 2 users liked this post by mental69:
John00 (12-16-18), Yona (12-19-18)
Old 12-16-18, 03:33 PM
  #114
John00
John00's Avatar
Thanks for the follow up. So how is the sound now?
Old 02-02-19, 08:14 AM
  #115
Im4real1
Im4real1's Avatar
Default Mark Levinson system sounds “hollow” tinny.
I recently purchased a 2016 Luxury GX. Love it so far, except for this supposedly great ML sound system. I’ve tried so many adjustments but can’t seem to get a full sound...Appears to miss “ channels “ of sound. Very weak base no matter the position. Best sound I can get is to position most sound to rear. I feel maybe sound speakers are not responding or maybe blown? Any advice is greatly appreciated. (I’m coming out of a 2011 Infiniti FX (had two for 16 years) which has fabulous Bose sound.)
Old 02-02-19, 08:39 AM
  #116
Romanova
Romanova's Avatar
Make sure it is adjusted properly? Ours sounds amazing and was a 'must have' when we were shopping for our GX. No matter what genre of music I play, it always sounds great. What source are you using for your music? If you're using low quality MP3s or streaming via BT, the quality might suffer.
Im4real1 (02-02-19)
Old 02-02-19, 10:40 AM
  #117
Im4real1
Im4real1's Avatar
Bluetooth sounds the best, actually! I’m going to try adjustments recommended in a prior post.
Old 02-02-19, 10:41 AM
  #118
Romanova
Romanova's Avatar
I'll try and remember to get a picture of my adjustments when I go out later. The system really sings when it's at volume level 35 or higher too...
Im4real1 (02-02-19)
Old 02-02-19, 10:49 AM
  #119
r2m
r2m's Avatar
Mine too sounds great! Just out of curiosity, what type of music are you into? Have you gone through the manual yet?
If you're into hip-hop, rap or other bass-centric genres of music at elevated volumes, yes you may be disappointed.
This was just discussed a few posts ago, and one suggestion I made was that you could add a small amp and sub-woofer.
Good friends of mine purchased new, two years ago a 2017 4Runner with everything and they too were disappointed with the sound and did just that, when to a quality sound shop and added an amp and sub-woofer. The new 4Runners are the essentially the same platform as our GX's (150 series). Note that my friends and I are in our mid to late 50's so if we're needing a bump in sound quality, it's not because we're trying to rattle windows going through neighborhoods.
Im4real1 (02-02-19)
Old 02-02-19, 04:55 PM
  #120
Im4real1
Im4real1's Avatar
That would be so great. Thank you!
Quick Reply: Mark Levinson (ML) discussion / questions / problems
